Old July 20, 2009, 05:13 PM
somecanadianguy's Avatar
Default SMP Gromacs WUs supposed to take so long?
First time I've run into something like this.
Can someone explain what's going on?
Should the SMP Gromacs Core WUs take that much longer than CVS?
What is the difference?
[19:16:35] Folding@Home Gromacs SMP Core
[19:16:35] Version 1.74 (November 27, 2006)
[19:16:35]
[19:16:35] Preparing to commence simulation
[19:16:35] - Ensuring status. Please wait.
[19:16:36] - Starting from initial work packet
[19:16:36]
[19:16:36] Project: 2665 (Run 2, Clone 847, Gen 136)
[19:16:36]
[19:16:37] Assembly optimizations on if available.
[19:16:37] Entering M.D.
[19:16:55] on if available.
[19:16:55] Entering M.D.
[19:17:03] Protein: HGG with glycosylations
[19:17:03] Writing local files
[19:17:05] Extra SSE boost OK.
[19:17:06] al files
[19:17:06] Completed 0 out of 250000 steps (0 percent)
[19:34:10] Writing local files
[19:34:11] Completed 2500 out of 250000 steps (1 percent)
[19:51:07] Writing local files
[19:51:07] Completed 5000 out of 250000 steps (2 percent)
[20:07:59] Writing local files
[20:07:59] Completed 7500 out of 250000 steps (3 percent)
I haven't noticed any of the other WUs "writing local files" between each step.
Old July 20, 2009, 06:25 PM
geokilla's Avatar
That project uses the older, A1 core and not the faster and more efficient A2 core.
Your PPD doesn't seem to be right for the A2 core WUs.
Old July 20, 2009, 09:37 PM
Really? What should I be getting?
I thought I was doing ok.
Old July 20, 2009, 09:43 PM
Arinoth's Avatar
You're getting more then i am with my i7 but i'm at stock and i average 1.7 to 1.8k ppd per core
Here I am: here I remain
Old July 20, 2009, 09:47 PM
I'm folding 3 VMware clients at 3.486GHz right now...
I usually get around 2500ppd per client.
If I run 4 clients I get around 2200ppd per client.
So long as they are the A2 WUs, that is.
I'm curious, Arinoth, why you're running stock speed?
These things are pretty easy to overclock.
Old July 20, 2009, 10:03 PM
Arinoth's Avatar
I am running stock because i'm using the stock heat sink and i typically only OC when i have after market (which i plan to eventually get and then OC). Also i 4 clients myself
Old July 20, 2009, 10:11 PM
geokilla's Avatar
Do you have hyperthreading enabled? I think I've seen more PPD from a Core i7 running the Notfred client.
If you fold 24/7, you can try running the 25k point WU. If you complete them in under 4 days, you get a bonus. However, the frame time for each percent is like 40+ minutes in order to be eligible for the bonus.
Old July 20, 2009, 10:31 PM
Arinoth's Avatar
If that question is directed to me, yes i do have hyper threading enabled and i do "try" to fold 24/7, i asked more questions about it in your own thread geokilla as to not go off topic in this one
SMP help Soultribunal HardwareCanucks F@H Team 9 May 28, 2009 06:57 PM
511 WUs Dwayne HardwareCanucks F@H Team 24 April 28, 2009 04:52 AM
1680 WUs ? CasheKicker HardwareCanucks F@H Team 9 March 10, 2009 06:09 PM
is the hdd supposed to be so loud? Bucklaz Storage 29 January 25, 2009 12:08 PM
Getting partial credit for WUs Alwaysrun HardwareCanucks F@H Team 3 November 10, 2008 07:41 PM
