Originally Posted by 3.0charlie The board may not be the culprit, the GPUs could be...
You said the GTX+ works.
But adding the Palit, it doesn't.
Then you said the Palit + 8800GTS neither.
Remember that folding on the GPUs puts a lot of stress on the cards, and could show instability. You know the GTX+ runs fine on its own, try running the Palit and the Asus on their own (I'd try the Asus first). Make sure the GPU temps are within acceptable limits.
How does it freeze? Is there a BSOD? |
There is no BSOD the mouse and keyboard simply wont work. Sorry I forgot to add I did have the Asus + Palit running fine, if only one used, and they also worked fine in other systems.
