Old July 14, 2009, 01:46 PM
kyle_L's Avatar
Default gpu folding in a wierd way,
ive started to get my gpu folding now and it just folds for a 1 second and stops for 3 seconds and repeats that proces anyone now whats going on, its a evga gts 250 and didnt do this the last time i folded on it.
Gotta Love Timmies Coffee.
Old July 14, 2009, 02:21 PM
Jon_di2's Avatar
I know that if you BOINC it gives you the option to do that... 25% so it would crunch for 1 second and then wait 3 seconds....
But as far as I know with F@H is that is happening, something is wrong... your gpu is overheating... problem with the installation, etc... never seen it so I'm not sure. I'd just delete F@H completely (uninstall and delete the folders). Then reinstall and see if it still happens.
Are you Ocing your videocard? and what are the temps on it?Restart your computer and see if it happens right away or it takes a few minutes plus+ to act like this.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old July 14, 2009, 02:39 PM
chrisk's Avatar
Folding Captain
Do you know which type of WU your gpu is currently working on? (ie. 511 points, etc). We used to get 420 point WUs that worked like that. Let a couple of WUs complete and see if it continues.
You also have latest drivers, etc.?
Fold for team #54196
Old July 14, 2009, 02:48 PM
kyle_L's Avatar
no overheating, overclocking and i have the latest drivers. i will fire it back up when im done on the pc.
Old July 14, 2009, 06:12 PM
CroSsFiRe2009's Avatar
Don't remember which WU it was, but some of them start and stop every couple seconds. It doesn't affect your ppd but it does reduce power consumption. I think in between the time its crunching numbers, it's doing error checking of some sort. Not entirely sure about all of this so guess you can hop on over to the Folding Forums and ask there too, couldn't hurt.
I actually find the starting and stopping annoying since I get some insane coil whine when I bump my shaders above stable everyday clocks. Since it's only shaders, you can usually crank it up pretty high but you also run the risk of EUE's. Stock shader clock for my 9600gso is 1375, oc'd is 1625 and folding is 1775. I'm just wondering if other people have this problem too when oc'n. /sry off topic
Old July 14, 2009, 06:26 PM
kyle_L's Avatar
i get the same coil whine thats why i dont like it.
Old July 14, 2009, 07:06 PM
Mine does that when my SMP isn't set to the same priority as the GPU.
Old July 15, 2009, 01:12 PM
kyle_L's Avatar
its a 472 WU
Old July 15, 2009, 10:46 PM
LCB001's Avatar
Folding Captain
The start and stop behavior is normal for the 472/1888 pt WU's, for some reason it seems more noticable on the GTX+/GTS250 series of cards.
There have been posts about this on the F@H forums like this one, Folding Forum • View topic - GeForce 9800 GTX+ stops and starts ...
Folding For Team 54196
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
Folding with 2 different gpu's gouki HardwareCanucks F@H Team 5 July 5, 2009 01:28 PM
Mixed GPU Folding CasheKicker HardwareCanucks F@H Team 22 March 25, 2009 03:26 PM
why is my 4870x2 only folding at 50% of ONE gpu.... divertiti HardwareCanucks F@H Team 6 January 9, 2009 10:06 PM
Newbie GPU Folding Shredder HardwareCanucks F@H Team 11 February 24, 2008 10:55 PM
