Old July 13, 2009, 03:45 PM
Silvgearx's Avatar
Default F@H + XP = sluggish/laggy web surfing?
I just notice i am getting terrible screen lag when Console GPU client is running in the background And it goes away when client is shut down.
Are you XP home users seeing the same problem?
I notice the GPU Client doesn't effect Vista Ultimate
anyway to fix the problem with some drivers or fixes?
currently using nvidia 185.85, XP with all updates.
Old July 13, 2009, 04:24 PM
Arinoth's Avatar
I find this happens to me sometimes with the gpu client and Windows 7, though i chalk it up to the fact i'm OCing the card, but i never thought it could be the drivers
Here I am: here I remain
Old July 13, 2009, 05:17 PM
Jon_di2's Avatar
I dont use the console client but I would suggest reducing the usage percentage to about 90-95%, you wont notice any problems then, slight reduction in ppd, but you will be able to watch videos and surf without issues. I had the same problem in xp, not using the same drivers as you, so I dont think thats the issue.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old July 13, 2009, 05:55 PM
geokilla's Avatar
GPU client causes Windows XP to lag. It's a very common problem. Turning on Windows Aero in Vista and Windows 7 makes the lag virtually disappear.
Old July 13, 2009, 08:00 PM
Jake_HT's Avatar
I got lag while GPU folding in XP, however seems to be better in vista...
http://jakeht.deviantart.com/
Old July 13, 2009, 09:04 PM
Silvgearx's Avatar
there is only cpu % usage available for gpu client
with core priority set to idle it doesn't screen lag as bad but i still get it
anyone got more suggestions that i can try? :help:
and since window 7 is so close by i don't want to spend $$ for another vista license
hopefully my pm when though and a certain person still wants to go ahead for the deal
Old July 13, 2009, 09:31 PM
geokilla's Avatar
Just install Windows 7 RC.
You can also go to Folding Forum • Index page and find the new, beta, un-released 1.19 core. With that core, you can set the GPU usage via environment variables. The downside is that your PPD will drop, but so will your lag and temps.
Old July 14, 2009, 08:58 AM
l-lunter's Avatar
used to happen to me when I had a GTX285, actually it used to lag doing pretty much anything while folding with that thing. Should have seen me trying to open azureus, omg it just wouldn't work lol. Back on my old 3870 I get no such problems, albeit I get so few points in comparison.
Old July 14, 2009, 10:32 AM
I don't seem to have this problem on XP, I use 64bit though.
Old July 14, 2009, 06:29 PM
Silvgearx's Avatar
Ok i update to nvidia drivers 186.18, it seems the lag screen is cut in half
but the screen lag is still there and its annoying as hell
might go hunt for a xp 64bit since i am not a fan of beta stuff
and pfft, i though nvidia had good driver support there no different the other team
if ati ever run F@H as good as nvidia, good buy nvidia
Sluggish 12cm fan? clone63 Air Cooling 5 May 27, 2009 04:58 PM
web camera CTA Peripherals 13 May 23, 2009 10:37 AM
Is it possible to watch tv while surfing net without tv tuner card joeyh HTPC Systems & Software 4 December 14, 2008 06:37 PM
laggy computer...I think its hardware related Computergeek Troubleshooting 36 March 29, 2008 06:51 AM
