  #51 (permalink)
Old July 4, 2009, 10:15 PM
Arinoth's Avatar
Originally Posted by gouki View Post
This is the guide i used to set up my clients but i only run 2 for cpu and 1 with gpu so i can do other things on my pc. Guide: Setting up notfred in VMWare Player - [H]ard|Forum. The only thing i changed was when i configured winafc to set priority and affinity i added theses lines. Now i don't have to watch to see if everything is set.
*\vmware-vmx.exe := PAIR0+PAIR1 [assign=2,priority=Idle,force=yes]
*\FahCore_11.exe := ALL [priority=High]
*\FahCore_14.exe := ALL [priority=High]
What the hell is winafc and what do those lines of code do, do i need to do them?
Here I am: here I remain
  #52 (permalink)
Old July 4, 2009, 10:19 PM
I see you are running gpu as well but it depends what else you do with your pc or if you want lots of ppd. You will get more points with your gpu but i like to play games or watch movies sometimes so i just use 2. Might try using 3 clients and 1 gpu to see if it really slows down my pc.
  #53 (permalink)
Old July 4, 2009, 10:20 PM
Arinoth's Avatar
Well my plan is to mainly run it when i'm not using my computer, since when i am using the computer its typically one the wanting to use the resources to what i'm doing. Oddly enough though, hfm.net wont properly update the progress % or anything with the GPU
  #54 (permalink)
Old July 4, 2009, 10:23 PM
WinAFC sets priorities to your cores so it doesn't mess up with your gpu folding. There a few ways to do this but i found this was the best for me as i don't have to do much once it's up and running. I'm not sure which guide you followed so maybe you already have it set some other way.
  #55 (permalink)
Old July 4, 2009, 10:25 PM
Arinoth's Avatar
Nah, its more or less the defaults other then the memory and the fact each are doing 2 cores is all. Now why would hfm.net isn't recognizing/updating the % and PPD for the GPU now, lol, why can't i have one monitoring program working for both applications of folding
  #56 (permalink)
Old July 4, 2009, 10:26 PM
Right click the GPU - F@H icon in taskbar then go to Status > Log file. Once you have that opened up look at launch directory and that's the folder you put in hfm.net.
  #57 (permalink)
Old July 4, 2009, 10:28 PM
Arinoth's Avatar
Yep, it doesn't have the progress/status or PPD updated/proper at all
  #58 (permalink)
Old July 4, 2009, 10:30 PM
Dumb question but did you unpause it? I saw in your ss that you had it paused. If not try resetting the gpu client.
  #59 (permalink)
Old July 4, 2009, 10:34 PM
Arinoth's Avatar
Yes i unpaused it, it just didn't want to update it at all, lol. Also did that, fahmon sees it working just fine for the gpu, thats the funny part of this.
Edit: it seems by changing the C to a lower case c and the f in fold to upper case fahmon seems to monitor it (the vmware cpu folding) now
  #60 (permalink)
Old July 4, 2009, 10:40 PM
Well that's the fun in folding is trying to figure out how it works. Glad you figured it out.
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
A few last questions before I start up... Barber Water Cooling 26 March 23, 2009 10:14 AM
About to start RainMaker New Builds 5 January 16, 2009 01:02 PM
cant get computer to start Defiant Troubleshooting 5 December 18, 2008 10:58 AM
Pc Start up Problem JuggsJr Troubleshooting 5 November 26, 2007 08:04 PM
