  #41 (permalink)
Old July 4, 2009, 09:49 PM
Arinoth's Avatar
With fahmon and vmware running i get this
Though when i look at the regular logs it says that same ridiculous % for the CPU as well. (GPU one is paused)
  #42 (permalink)
Old July 4, 2009, 09:51 PM
Oh right i rememebr now because i had the same problem before. There is a box you have to tick saying client is on virtual machine and that should fix it. Just edit client and you should see option near the bottom.
  #43 (permalink)
Old July 4, 2009, 09:53 PM
Arinoth's Avatar
Yeah i tired that, using \\192.168.0.102\C\etc\folding\1\ as the address to monitor and i still get the fun messed up % number
  #44 (permalink)
Old July 4, 2009, 09:55 PM
Edit client and put this in minus the quotes " \\fold-cd76\C\etc\folding\1\ "
  #45 (permalink)
Old July 4, 2009, 09:58 PM
Arinoth's Avatar
Now its says progress is N/A, ETA N/A and the rest is " - " excluding the name i gave it
Edit: If you're planning on spending some time helping me, i'm in the HWC irc. Its also back to that crazy % number again
  #46 (permalink)
Old July 4, 2009, 10:02 PM
You replaced \\192.168.0.102\C\etc\folding\1\ with \\fold-cd76\C\etc\folding\1\ you mean and that happened?
  #47 (permalink)
Old July 4, 2009, 10:04 PM
Arinoth's Avatar
Yep, ended up with the same crazy %, could it be vmware? I've set it up a couple times and i keep getting that as still
  #48 (permalink)
Old July 4, 2009, 10:06 PM
I was having problems with fahmon so i ended up using hfm.net which you don't even have to install anything. Anyway here is ss of my settings which should be about the same as fahmon.
  #49 (permalink)
Old July 4, 2009, 10:12 PM
This is the guide i used to set up my clients but i only run 2 for cpu and 1 with gpu so i can do other things on my pc. Guide: Setting up notfred in VMWare Player - [H]ard|Forum. The only thing i changed was when i configured winafc to set priority and affinity i added theses lines. Now i don't have to watch to see if everything is set.
*\vmware-vmx.exe := PAIR0+PAIR1 [assign=2,priority=Idle,force=yes]
*\FahCore_11.exe := ALL [priority=High]
*\FahCore_14.exe := ALL [priority=High]
  #50 (permalink)
Old July 4, 2009, 10:13 PM
Arinoth's Avatar
HFM.NET seems to pick it up now, should i run 4 of these when i'm going for full folding, or just 1-2?
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 09:54 AM
A few last questions before I start up... Barber Water Cooling 26 March 23, 2009 10:14 AM
About to start RainMaker New Builds 5 January 16, 2009 12:02 PM
cant get computer to start Defiant Troubleshooting 5 December 18, 2008 09:58 AM
Pc Start up Problem JuggsJr Troubleshooting 5 November 26, 2007 07:04 PM
