  #21 (permalink)
Old July 2, 2009, 04:26 PM
chrisk's Avatar
Folding Captain
Originally Posted by Arinoth View Post
Loads of help, got my GPU folding going right now on the basic settings
I would fold at stock for a day or two, just to get a feel for how many PPD your card gets, temps while folding, etc. We also need to know if your rig is 'folding stable'. Folding is ver stressful on a system, so establishing a base 'stability' is important. Then you can look at OCing those shaders.
Fold for team #54196
  #22 (permalink)
Old July 2, 2009, 05:37 PM
I use Evga precision to adjust my GPU fans. My target temps are 75C and lower. Right now I'm at about 72C with the fans on my GTX's at 80%.
  #23 (permalink)
Old July 2, 2009, 05:39 PM
Arinoth's Avatar
I only ask because running the default GPU folding i'm at about 65C at default settings for the card as well
  #24 (permalink)
Old July 2, 2009, 05:42 PM
Arinoth's Avatar
I just downloaded it, installed it, and saw that with the temp of 65 the fan was on auto at 40%. I put it to 80% and it was rather loud, maybe i'll play with it till i get a volume db that i like
  #25 (permalink)
Old July 2, 2009, 05:43 PM
chrisk's Avatar
Folding Captain
You have an Evga card so the precision tool hertz mentioned is good if the temps are too high for your liking. I run my fans at 80% using it.
  #26 (permalink)
Old July 2, 2009, 07:08 PM
Arinoth's Avatar
Using the EVGA precision tool with the fan at 60% temperatures are floating down around 55C with otherwise stock settings for the GPU and GPU folding. I take it its not that hard to OC this GPU up a bit more to benefit in games and folding as well
  #27 (permalink)
Old July 2, 2009, 07:14 PM
Arinoth's Avatar
The 1888s means it gives you 1888 credit, remember i'm new to this and trying to understand as much as a i can
  #28 (permalink)
3.0charlie's Avatar
Be careful, the temps can swing depending which WU is being folded. The 511s and the 1888s are notorious for high temps.
  #29 (permalink)
Old July 2, 2009, 10:26 PM
chrisk's Avatar
Folding Captain
My advice is to wait a couple of days, and pay close attention to the temps on the 511s (it is customary around here to place a "" in front of the 511, as we hate them so much. Long-time HWC folder LCB001 started this tradition. I rather think the 511s are an opportunity to really test your rig. That way, the 511s are a somewhat welcome sight. Otherwise, how else would you be able to use the smiley without the 511s hanging around. We would be sitting around, thinking like, 'How can I use the smiley.' 'I can't think of one way to use the thing'. But thanks to the 511s, we have ample opportunity to use the smiley.)
Go through a few 511s first, then try some OCing.
  #30 (permalink)
Old July 2, 2009, 11:25 PM
To quote the great Mr. Gump, well kind of, "Folding is like a box of chocolates, you never know what you are going to get next." That is why I run my fans at 80%. 511s
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 09:54 AM
A few last questions before I start up... Barber Water Cooling 26 March 23, 2009 10:14 AM
About to start RainMaker New Builds 5 January 16, 2009 12:02 PM
cant get computer to start Defiant Troubleshooting 5 December 18, 2008 09:58 AM
Pc Start up Problem JuggsJr Troubleshooting 5 November 26, 2007 07:04 PM
