Originally Posted by Arinoth I am completely new to folding, actually never had heard of it before joining these great forums. Just installed cuda so i am restarting (have the gpu client downloaded and installed) |
Wicked!
1. Just to make sure, you have downloaded this client:
http://www.stanford.edu/group/pandeg...ystray-623.msi
The above is the "High-performance GPU client" , often called the System Tray client. This client will show a small folding icon in your system tray (ie. next to the clock). There is another client called the "Console Client" which i did not link to, which does not put the icon in the tray, but works in a command prompt window instead.
2. Follow this excellent guide here:
[H]ard|Forum - View Single Post - [H]orde Guides
Every step is laid out very good in that guide.
3. As for your folding username, there is no sign-up. You just enter it in the client and the points go to that account. Good news for you, your username
Arinoth is not being used. I checked it here:
http://fah-web.stanford.edu/cgi-bin/...type=userstats
Again, there is no sign-up...just enter Arinoth into the username field of the software you downloaded.
4. Now you have some folding happening after the guide was followed in Step 2 above, you want to monitor how its going. Follow this guide I have created here:
http://www.hardwarecanucks.com/forum...-progress.html
Use the FahMon program in step 4 above to monitor your progress. Don't use the folding icon next to your tray, as its buggy and slows down the process.
After this is done and you are comfortable that your rig is folding-stable, we will work on maximizing PPD via GPU OC, etc. later on.
Some terms to know to get started:
PPD - Points Per Day. The higher you go, the better it is. Your GTX 260 should manage 5000 PPD at stock. This does depend on the stuff your GPU is working on, so it can fluctuate.
WU - Work Unit. This is the data sent to your computer, that is worked on, and sent back to Stanford University. There are different point values for these. A 768 point WU will get you 768 points when submitted on time. FahMon (see step 4 above) wil tell you how many days you have to get it done. The 511 point WU is hated by folding people, as they really stress out your system, and slow down and thus reduce, your points per day.
FahMon: Folding at Home Monitoring program. Used by many to see how their computer is coping with folding, and other info. A competitor program is called FahSpy, which is better in many ways, and offers much more information. For now, I recommend FahMon to start, as it just gives you the info you really need to start.
Shader: this is a part of the GPU which does much of the folding work. If you want the most PPD out of your video card, overclocking the shaders is the best way to go. To overclock the shaders, RivaTuner is good, or an overclocking program offered by your video card maker.
