Old May 20, 2009, 07:11 AM
Default Shader vs ppd
Hi, i check to up my shader on my 260 216, oc it is not the problem,
but to be sure, only the shader up the ppd?
can i downclock the core and ram without losing ppd?
Old May 20, 2009, 07:31 AM
Synth's Avatar
Yup, just upping the shader processors' speed will give you higher ppds, but do not underclock your core, you might lose some points. Or try both, and see if there's a difference.
Personally, I had underclocked my 9600GSOs' core speed, just to have cooler running cards, and lost 350ppds per card.
Just leave it at stock (the core) and OC the shaders.
Bonne chance pour le folding mon vieux, et bienvenue dans l'équipe
Old May 20, 2009, 07:32 PM
dhoshaw's Avatar
Originally Posted by Synth View Post
Yup, just upping the shader processors' speed will give you higher ppds...
Hey Synth, is the PPD boost worth the extra heat?
Intel Q9550 @3.8 GHz
Sapphire 5850 Toxic
XFX 9800GX2
Xigmatek Dark Knight
Gigabyte GA-EP45-UD3P
2 x 2 GB Corsair XMS2 1066C5
2 x WD 640 GB Raid 0 + WD 1 TB
Haf 922 / Antec Signature 850
Windows 7 Ultimate x64
Old May 20, 2009, 07:50 PM
Prof. Dr. Silver's Avatar
Ofcourse it is worth it! Anything helps man! Make your room/house/street a few degrees warmer! It is for a good cause afterall.
Without kidding: Just add an extra fan to blow on your card.... works well
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old May 21, 2009, 04:39 AM
Shader oc to 1475
thaks for your reply guys
Old May 21, 2009, 06:30 AM
dhoshaw's Avatar
Right now it's in a temporary case and I have a 20" floor fan blowing on it; I suppose it could withstand some oc.
Sapphire 5850 Toxic
XFX 9800GX2
Old May 21, 2009, 08:06 AM
Soultribunal's Avatar
Now that sir, Is how you do it!!!!
ST
www.realhardwarereviews.com
ATI Shader Clock Adjustment Shredder HardwareCanucks F@H Team 2 March 31, 2009 10:16 PM
Shader Process OC Alwaysrun HardwareCanucks F@H Team 6 January 16, 2009 10:48 PM
The end of 65nm/192 Shader GTX 260's is here! chouchou Video Cards 3 November 18, 2008 06:52 AM
Looking for a shader for a laptop mazabe Mobile Computing 2 May 9, 2008 01:15 PM
cant overclock shader clocks magictorch Overclocking, Tweaking and Benchmarking 2 February 29, 2008 08:29 AM
