Old May 17, 2009, 04:58 PM
Pike's Avatar
Question Comments for startup
I've read all that I can and now this is where I'm at.
I wanted this to start yesterday so I installed the systray main CPU client v6.23. Already have 1 WU done but only getting 280 PPD (according to FahMon). My system is:
E8400 on a Gigabyte EP45-UD3L
4GB OCZ DDR2 PC2-8500 1066mhz (running at 800)
Sapphire HD4670 512mb
Seagate 320GB SATA II
OCZ 500 PSU
Questions are:
Am I running the correct client?
Should I upgrade to the High performance CPU and GPU clients?
If I stay with the current client, how can I increase my PPD?
Thanks
Old May 17, 2009, 05:13 PM
3.0charlie's Avatar
Am I running the correct client? No. For the CPU, use the Beta SMP Client. Or you can choose to install one Vmware client for 1 core, and use the second core for a GPU client (needs some CPU cycles).
Should I upgrade to the High performance CPU and GPU clients? Yes, for the CPU. For the GPU, choose the Systray client.
If I stay with the current client, how can I increase my PPD? 2 ways of increasing your ppd: using the correct client for your configuration, and overclock your CPU / GPU shaders.
Old May 17, 2009, 05:23 PM
Pike's Avatar
Should I just stop the current client...uninstall and then install the Beta SMP client for the CPU and GPU or should I let it finish the current WU?
Old May 17, 2009, 05:25 PM
3.0charlie's Avatar
For the ppd that the STD client offers, stop it. It's not worth the wait - the SMP and VMware clients yield a whole lot more ppd.
Make sure you follow the guides at the FAH site, or the Vmware guide located here.
Old May 17, 2009, 05:27 PM
Pike's Avatar
Thanks for the info. I'm on it :)
Old May 17, 2009, 05:31 PM
3.0charlie's Avatar
No problem.
The FAH guides are here: Folding@home - Guide.
The Vmware guide is here: Boost Your PPD with VMWare - Look inside for easy guides!.
Old May 17, 2009, 05:35 PM
Pike's Avatar
One more question. Two versions of the CPU client:
6.23 beta for Deino MPI (32-bit only) and 6.23 beta for MPICH (32-bit or 64-bit). I'm using Vista Ultimate 32bit. Which one Charlie?
Old May 17, 2009, 05:38 PM
3.0charlie's Avatar
MPICH is the one you want.
Make sure you run the install.bat file, and you'll need a Vista user password for that client to work.
Old May 17, 2009, 06:35 PM
Pike's Avatar
Ok, got both clients running however the CPU doesn't register on FahMon (is showing but registers NA and staying at 0%). I tried unloading the client and reloading (through FahMon) and still the same but task manager say that fahcore_11.exe (PID:2648) is running at around 50%. Can't figure that out yet. How can I stop and restart this service? Through services.msc?
Temps are: 51c for the CPU and 61c for the GPU
PPD: GPU 1148 and nothing shown for the CPU
Anything missing here? besides O/C the cpu and GPU?
Thanks
Old May 17, 2009, 06:40 PM
3.0charlie's Avatar
You linked the incorrect folder. 50% is normal, since with dual cores you usually need 2 clients. But since you are using an ATI gpu, you can't use dual CPU clients.
CPU usage is only 50%?
Anyone have an X6 Keyboard ? Comments ? BMWDriver Peripherals 12 March 18, 2009 07:51 PM
No display on monitor upon startup. HELP! bojangles Troubleshooting 20 October 31, 2008 08:53 PM
HELP! Wondows live messanger hangs on system startup ? 49-parallel O/S's, Drivers & General Software 21 October 1, 2008 05:14 PM
WTF - Windows Logging Me off on Startup CasheKicker Troubleshooting 9 March 25, 2008 08:25 AM
Request for comments low351 Case Mods, Worklog & Gallery 20 March 5, 2008 12:56 PM
