Old April 24, 2009, 07:08 PM
Default Need help setting VM Folding
Ok guys, I'll be needing some help on this one...
I Installed Server 2008 x64 on my Q6600 with Hyper-V.
I found a utility called VMDK2VHD that converts VMDK files to VHD then followed instructions from ZLOKACK's thread on setting up the VM as per the evga guide and everything works up to the reconfiguration step.
At that step, I connect in internet explorer using the VM's IP adress... still no issue but when I go in the reconfiguration page, enter my data then click "Reconfigure" and reset the VM, I find that it did not reconfigure the user, team and memory. I also tried turning off the VM then reboot... no difference.
I also tried reconfiguring through FAHSpy (hold ctrl and click on Folding Alias) then reboot or reset... no difference. I always come back to notfred2630's user name and team.
Any ideas?
Old April 24, 2009, 07:24 PM
SugarJ's Avatar
Just to confirm, you did the remote reboot after configuring?
Old April 25, 2009, 06:10 AM
Yes... Tried a reboot through reset as well as shut down then restart.
Old April 25, 2009, 07:48 AM
3.0charlie's Avatar
Have you tried the other link? Core i7 Folding - how to increase your PPD - Xtreme CPU It's a different way of setting up the VMs. It may be an issue with Server 2008.
Hydro-Quebec is salivating...
Old April 25, 2009, 08:05 AM
Nope. But the issue isn't with setting up the VM itself but rather changing the configuration of the Folding client on the VM.
Old April 25, 2009, 02:12 PM
3.0charlie's Avatar
I meant that configuration under IE may be an issue under Server 2008.
Old April 27, 2009, 05:27 AM
I tried configuring through Firefox and Chrome with same issue.
What I'll do is go through the setup as described in the guide on my E8400 then copy the VM files over to Hyper-V. Hope this works.
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
Fatal1ty setting Computergeek Audio 2 July 3, 2008 06:04 PM
bios setting maurier CPU's and Motherboards 6 June 24, 2008 09:50 AM
Best setting for E6600 Digital_Fortress Overclocking, Tweaking and Benchmarking 0 April 23, 2008 10:44 PM
