Old April 23, 2009, 01:42 PM
Default SMP client help
Hi, i try to fold with the smp client but i think i do something bad...
i instal fahmon and see i only get 240ppd with my cpu, and it never load over 30%...
that is the smp client i got
FAH6.23beta-win32-SMP-deino
i try to ask it to use 100% in sething first time i setup it but i dont do nothing...
what to do to load my cpu at 100% with this client?
Thanks
Phil
Old April 23, 2009, 02:19 PM
geokilla's Avatar
Folding@home - WinSMPGuideDEINO
Additional client parameters []?
You can enter the client flags here so you don't have to type the flag each time. I strongly suggest you enter the -smp -deino -verbosity 9 flag here to make things easier. Don't enter -config or -configonly or any single-use flag to avoid issues.
Old April 23, 2009, 02:23 PM
werty316's Avatar
Did you add the "-smp" and "-deino" flags?
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old April 23, 2009, 02:26 PM
Jon_di2's Avatar
ahahaha I did the exact same thing! Stupid SMP client... It was running at load on all 4 cores on my q9450 but going so slowly... not sure why...
I gave up and ran regular clients on each core.... much higher ppd!
I did that... didn't try without it though...
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old April 23, 2009, 02:52 PM
stoanee's Avatar
VMWare ubuntu folding works MUCH better. I gave up on the windows clients long ago.
heatware
Old April 23, 2009, 03:38 PM
maybee more expliquation loll, i dont know anything about the smp client...
thanks
Phil
Old April 23, 2009, 04:14 PM
It's now loaded at 100%... but with 1 gpu2, 5 normal client and 2 smp client....
Old April 23, 2009, 05:10 PM
LCB001's Avatar
Folding Captain
The SMP is meant to replace the usual cpu client, you won't make the deadlines with that many clients running.
The SMP client will load all your cores by itself...
Folding For Team 54196
Old April 23, 2009, 05:51 PM
that is why i make this post... i cant load all my core with only the smp client...
Old April 23, 2009, 06:42 PM
LCB001's Avatar
Folding Captain
Are you running an i7 by chance ?, if so 2x then SMP client would do it. Each SMP instance can load 4 cores, just make sure the priority on your GPU client is slightly higher to make sure it gets enough cpu cycles. Add the -smp flag at the end of the target line on your shortcut.
Without knowing you system specs and OS it's hard to advise you on what clients to use.
Folding with SMP Client - Nodda Happening CasheKicker HardwareCanucks F@H Team 43 February 28, 2009 07:29 AM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 06:47 PM
Goodbye SMP client ! BrainEater HardwareCanucks F@H Team 3 November 2, 2008 04:17 PM
SMP client errored BrainEater HardwareCanucks F@H Team 8 October 9, 2008 05:50 PM
Hlpwith SMP client magictorch HardwareCanucks F@H Team 4 April 7, 2008 07:50 PM
