I've been battling with this for a couple of days now. Three of my four GPUs are folding along nicely, while the fourth gets UNSTABLE_MACHINE and EUEs.
I've tried two different drivers so far (182.08 and 182.50) and the same thing happens on both.
My system is in my sig. Vista 64 is the OS. I am running with dummy plugs on the cards and using the GPU client meant for nVidia cards. (Folding@home-Win32-NV-GPU-systray-623)
I'm going to try swapping the cards to different slots tonight and see if it's specific to that card or if it's the fourth GPU in general. I hope I don't have to RMA
Here's what my log says
Code:
[04:13:39] + Attempting to send results [April 23 04:13:39 UTC]
[04:13:39] + Results successfully sent
[04:13:39] Thank you for your contribution to Folding@Home.
[04:13:43] - Preparing to get new work unit...
[04:13:43] + Attempting to get work packet
[04:13:43] - Connecting to assignment server
[04:13:44] - Successful: assigned to (REMOVED).
[04:13:44] + News From Folding@Home: GPU folding beta
[04:13:44] Loaded queue successfully.
[04:13:45] + Closed connections
[04:13:50]
[04:13:50] + Processing work unit
[04:13:50] Core required: FahCore_11.exe
[04:13:50] Core found.
[04:13:50] Working on queue slot 05 [April 23 04:13:50 UTC]
[04:13:50] + Working ...
[04:13:50]
[04:13:50] *------------------------------*
[04:13:50] Folding@Home GPU Core - Beta
[04:13:50] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[04:13:50]
[04:13:50] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:13:50] Build host: amoeba
[04:13:50] Board Type: Nvidia
[04:13:50] Core :
[04:13:50] Preparing to commence simulation
[04:13:50] - Looking at optimizations...
[04:13:50] - Created dyn
[04:13:50] - Files status OK
[04:13:50] - Expanded 46725 -> 252912 (decompressed 541.2 percent)
[04:13:50] Called DecompressByteArray: compressed_data_size=46725 data_size=252912, decompressed_data_size=252912 diff=0
[04:13:50] - Digital signature verified
[04:13:50]
[04:13:50] Project: 5766 (Run 0, Clone 308, Gen 456)
[04:13:50]
[04:13:50] Assembly optimizations on if available.
[04:13:50] Entering M.D.
[04:13:56] mdrun_gpu returned
[04:13:56] Going to send back what have done -- stepsTotalG=0
[04:13:56] Work fraction=0.0000 steps=0.
[04:14:00] logfile size=0 infoLength=0 edr=0 trr=25
[04:14:00] - Writing 637 bytes of core data to disk...
[04:14:00] Done: 125 -> 124 (compressed to 99.2 percent)
[04:14:00] ... Done.
[04:14:00]
[04:14:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:14:04] CoreStatus = 7A (122)
[04:14:04] Sending work to server
[04:14:04] Project: 5766 (Run 0, Clone 308, Gen 456)
[04:14:04] + Attempting to send results [April 23 04:14:04 UTC]
[04:14:05] + Results successfully sent
[04:14:05] Thank you for your contribution to Folding@Home.
[04:14:09] EUE limit exceeded. Pausing 24 hours.
