Old April 17, 2009, 09:54 AM
Jon_di2's Avatar
Its all good, thanks for the help!
I cant use Vista anyways since I dont have 4 monitors laying around (nor would I want 4 set up...) But Since it is working in XP, its all good!
Oh I'll try the beta version too!
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old April 17, 2009, 11:36 AM
chrisk's Avatar
Folding Captain
Hey Jon;
Looks like you are happy with your XP setup. In the future, you want to run F@H on Vista, post a message on here about how to make a 'dummy plug' that tricks Vista into thinking you have a monitor connected when you have not. If you have three video cards, then you definitely have three VGA adapters that came with them, so all you would need to pick up are three resistors and some electrical tape. You just pop the resistor in the right holes in the VGA adapter, and use some tape to hold it in place. No soldering or taking things apart!
Fold for team #54196
Old April 17, 2009, 11:58 AM
Nademon's Avatar
Yup! I have 3 dummy plugs in my dual 9800GX2 setup and they work like a charm! I'll never go back to the systray client. The console client has proven to be superior in every way for me.
REFS:
My Heat, Ebay, RedFlagDeals
Rig 1: CM HAF - Rampage Extreme - QX9650 - OCZ Gladiator Max - 4GB Mushkin DDR3 1600 - GTX280 - 2xBarracuda 500GB - 1xBarracuda 250GB - Pioneer DVD - Corsair 1000HX
Rig 2: Thermaltake Armor - P5K-E - E3110 - TRUE w/ 2 120's - 4GB Ballistix DDR2 1066 - 9800GX2 - 2xBarracuda 250GB - Pioneer DVD - Corsair 620HX
Rig3: Antec 900 - P5K-E/Wifi - E5200 - OCZ Vendetta 2 - 4GB OCZ DDR2 800 - 2x 8800GTS's - 1xWD Caviar 80GB - Pioneer DVD - OCZ 650W PSU
Old April 17, 2009, 01:51 PM
Dwayne's Avatar
I have one dummy plug, no tape required if you are careful, works fine on my 295. One thing I did find though, the bottom DVI plug is primary (teach me to read the manual before I hook up my monitor) I had it in the top, and when it was 1 monitor it was ok, but when I connected the dummy plug my boot screen became the dummy plug! Fun fun.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old April 22, 2009, 12:51 PM
Jon_di2's Avatar
I'm thinking I might want to try this out just to see if it will work, and to see if Vista would make any difference in PPD... I have 6 or seven of these adaptors so I'll just have to grab a few 68 ohm resistors and see how it goes
The 30 Second Dummy Plug - Overclock.net - Overclocking.net
I might stick with this setup though, cuz this way I dont have to stop F@H and enable SLI when I want to play a game, I just reboot and go into Vista and its set up.
Old May 24, 2009, 01:15 PM
Phobia's Avatar
I'm going to Necro this thread.
I've been having troubles setting up my 2nd GPU client. I downloaded the latest console client. Ive got one GPU working, but am unsure of how to get the other working. Am I using the wrong client? Should I use the systray client instead?
Old May 24, 2009, 01:46 PM
chrisk's Avatar
Folding Captain
Are you getting any error messages? What two cards are you trying to use in the same rig? Some cards don't mix well.
I only use the systray client myself. When I have added a second cpu, I have done the following:
1. removed the drivers in control panel, and used driver cleaner to remove all driver traces.
2. placed new card in, installed new drivers
3. used Xilikon's excellent guide to configure the clients properly: [H]ard|Forum - View Single Post - [H]orde Guides
Old May 24, 2009, 01:52 PM
Phobia's Avatar
I've got 2 gtx260 core 216's. I copied the folder i had, and renamed it, but it just said that there was a project already going on, or something like that. I'll probably just end up moving everything to the systray client.
  #19 (permalink)
Old May 24, 2009, 01:55 PM
chrisk's Avatar
Folding Captain
Was the folder you copied already used by a folding program? You should start with fresh files in each folder.
  #20 (permalink)
Old May 24, 2009, 02:05 PM
Synth's Avatar
No.
Aside from needing 2 separate folders, you need to insert "-gpu 0" and "-gpu 1" to each of your f@h executables.
How to fold with multiple cards? Cptn Vortex HardwareCanucks F@H Team 16 January 2, 2009 08:46 AM
Multiple systems in one case yamawho New Builds 7 October 2, 2008 02:05 PM
FS: Multiple items Mindwarp Buy/Sell & Trade 2 June 1, 2008 07:31 AM
a couple of issues [ram & GPU] Psycho-Designs Troubleshooting 5 May 2, 2008 06:20 AM
FS: Multiple Items Dark Buy/Sell & Trade 0 December 28, 2007 11:04 PM
