<~----> Can't find the solution... - Hardware Canucks
Old April 12, 2009, 05:52 AM
Gellidius's Avatar
Default Can't find the solution...
Yesterday i installed two new programs and some time later i started hearing a sound from the speakers, every few seconds, something sounding like "thump" or "tom" (not a "ding" or "dung" ) that one hears when Windows or other programs come on when rebooting. So, i checked config for those 2 new programs and eventually for many others, but did not find any solution to this.
It was still doing it this morning and as i was still trying to settle that, the sound suddenly stopped, and soon i heard the GPU fan slowing down a little.
I checked in FahSpy and found that the GPU had just finished processing one of those 511's.
Does anyone know how i can turn off that sound if/when a 511 is processed again?
Would this have to do with the fact that yesterday i increased my cpu oc to 3500MHz?
My temps are all below 55C working Rosetta@Home on 4 cores and GPU temps never go above 65-66C.
Jacques
Ego cogito, ergo deus non est.
Old April 12, 2009, 09:02 AM
Perineum's Avatar
Now I'm not exactly sure what it is that you're hearing but I have noticed a sound coming from several different computers when folding with the GPU client. For the most part what I hear is a 5 or 6 second long whine with a pause, then repeated endlessly while folding. The sound seems to change depending on what kind of thing you're folding too.
If that is what you're hearing then I don't have an answer for you.... does anyone else hear this too?
Old April 12, 2009, 12:05 PM
Shadowmeph's Avatar
I think that you can turn the sound effects off when folding if that is where the sound comes from
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Coil whine from GPU you can't turn that off.
Old April 12, 2009, 12:13 PM
Gellidius's Avatar
i just found which sound it makes by trying those that are found in Windows Media;
it's called "Windows XP ding", (not "ding").
Jacques
Old April 12, 2009, 01:09 PM
Gellidius's Avatar
I checked all the logs in my pc, and none says anything about what's happening.
A few mins. ago a new 511 started and i'm hearing this "Windows XP ding" again, avery 5 to 15 secs.
i don't think it's warning me about some errors, as those WU end with success, so in reality it's not very important,
but i sure would like to know why it's doing this.
Jacques
Old April 12, 2009, 01:13 PM
reaverclan's Avatar
b4 u said it was xp ding i thought maybe your cell phone was doing it as my phone can make any tv/speaker go insane lol.
The-Jew/Xfire=reaverclan/My Photobucket
mobo:GA-P35-DS3L Rev.2(BIOS F7)
os:
Win7 Pro x64/Ubuntu 9.10 x64
cpu:Q6600@3040.0GHz
cooling:
OCZ Vendetta 2 ram:4GB(4x1GB) Corsair XMS2 800 4-4-4-12
gpu:EVGA GTX280 SSC hdd:Seagate 1024GB psu:HX620w
disp:
Vizio 1080p TV (32'') sound:X-Fi Xtreme Gamer case:Antec 1200
Old April 12, 2009, 01:18 PM
Gellidius's Avatar
i don't have a cell phone...
i just put the gpu on pause, and the ding stopped;
when i start the gpu again, the sound starts...
it all seems very mysterious to me.
I think i will lower the clocks on the gpu and see what happens...
Edit: lowering the clocks on the gpu has no effect.
Jacques
Old April 12, 2009, 01:38 PM
Gellidius's Avatar
GOTCHA !!!
Finally found it.
Yesterday i oc'd from 3.4 to 3.5; this upped the current load, specially when doing a 511 WU which draws a lot of current.
My UPS is a Belkin, and the load meter used to indicate around 66-68%, in the green, with the oc at 3.4;
Now, with the oc at 3.5, the total load on the UPS has gone up, and when the amperage on the gpu has a spike (up to 105A.),
the load on the Belkin goes up to around 72%, in the yellow, and it warns me about an "impending overload" by ringing the bell. haha!
Thanks to all who tried to help me. :-)
Jacques
Old April 14, 2009, 12:55 AM
reaverclan's Avatar
np glad u got it fixed
os:
cpu:Q6600@3040.0GHz
cooling:
disp:
Booting Problem, Possible Solution? ImmaPC Storage 8 November 27, 2008 07:35 PM
For Those of You Who Hate UPS...DC has your solution SKYMTL Off Topic 27 November 20, 2008 05:42 PM
IBM's watercooling solution magictorch Water Cooling 0 June 6, 2008 06:06 AM
Need New WC Solution e_1337 Water Cooling 22 March 15, 2008 06:46 PM
Cooling Solution for Pentium D 3.6 wpurcell Water Cooling 7 July 11, 2007 09:30 AM
