  #41 (permalink)
Old April 17, 2009, 06:15 PM
chrisk's Avatar
Folding Captain
What cpu you have? How many instances of the vmware do you have up?
Fold for team #54196
  #42 (permalink)
Old April 17, 2009, 06:16 PM
chrisk's Avatar
Folding Captain
Originally Posted by geokilla View Post
I think you need to start up the VMware, or at least set it up as a service. I have yet to hear of people running VMware folding as a service.
@ImmaPC. What's your system rig? Do you have the -smp flag?
As far as I know, if you use the Evga setup zlojack mentioned you don't need to set the -smp flag.
  #43 (permalink)
Old April 17, 2009, 06:19 PM
ImmaPC's Avatar
My rig is:
Core i7 920
eVGA X58
6GB DDR3-1600
4850
..Currently running 4 VM's at once...
I don't know if I have the -smp flag, how can I check and how can I set it to that flag? I used the second guide (i.e. NOT the eVGA one).
There's a line in FahSpy monitor that says:
Arguments: -local -forceasm -smp 2
I guess it means that they have the smp flag. They are all under the same Machine ID, is that why? How can I change the machine ID?
Rigless. Secret project in the works.
  #44 (permalink)
Old April 17, 2009, 06:45 PM
geokilla's Avatar
Try using the Legit Reviews guide. 400+ PPD is definitely wrong for a Core i7.
I don't know how to use the first guide because it doesn't work with my rig in sig. You could try using the Legit Reviews guide. There's been some members on my team who use that guide and their VMware runs just great.
  #45 (permalink)
Old April 17, 2009, 06:47 PM
3.0charlie's Avatar
Originally Posted by ImmaPC View Post
My rig is:
Core i7 920
eVGA X58
6GB DDR3-1600
4850
If it helps at all, it says that it is using the GROMACS core...shouldn't it be using SMP? Am I totally talking out of my rear?
Wrong core. Should be GROCVS. Use the evga forum thread. Works like a charm.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
  #46 (permalink)
Old April 17, 2009, 06:52 PM
ImmaPC's Avatar
Should I un-install VMWare and start over completely, or would it be O.K. to play with what I got already?
I dunno, I think I'll do it clean. All the clients are folding under Machine ID 1, should I change that too? How do I change it when I'm folding on multiple VM's?
  #47 (permalink)
Old April 17, 2009, 06:54 PM
3.0charlie's Avatar
Un-install everything. Follow the evga guide to the T. No need to play with IDs, since the Vmware Players are environments on their own.
  #48 (permalink)
Old April 17, 2009, 06:57 PM
ImmaPC's Avatar
But the EVGA guide is for Q6600, I'm on i7. I guess I'll do everything I need to do twice, twice...right? =D
  #49 (permalink)
Old April 17, 2009, 07:04 PM
3.0charlie's Avatar
Depending on your ram amount, you can setup up to 4 vms.
  #50 (permalink)
Old April 17, 2009, 07:12 PM
ImmaPC's Avatar
I got 6GB...that's good for 4 VM's, 1.5 each...not too bad, right?
QUESTION! Should I open up the .vmx file in notepad and change the mem usage, the name, etc. like in the 2nd guide? (Xtreme CPU)
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 08:28 PM
Some help getting VMWare and SMP up and running zlojack HardwareCanucks F@H Team 54 May 3, 2008 10:40 PM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 05:03 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
