  #221 (permalink)
Old June 11, 2009, 10:23 AM
SugarJ's Avatar
When you are trying to add the client in fahmon, add /1 to your IP. i.e. 192.168.1.195/1 . The fahlog.txt is in a subdirectory called 1.
  #222 (permalink)
Old June 11, 2009, 10:57 AM
Jon_di2's Avatar
Originally Posted by JMCD View Post
Also a question about priorities, GPUs should be low and SMP normal/high?
Good question... I'm doing the reverse and its workin out...
specs: Q9450 & Two Gtx 260's
2 instances of VMWare with Priority changed to Low and the GPU's priority I have left untouched. If I leave the folding on VMWare priority at normal it kills the ppd on my gpu's.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
  #223 (permalink)
Old June 11, 2009, 11:09 AM
Yeah I had to boost mine on the GPU's to normal, I suppose it doesn't matter as long as they're all on the same level of priority.
SugarJ, just tried that and apparently no such luck. I''ve tried my internal IP as well as the IP in VMWare and variations of it. Looks like this - \\192.168.1.110\c\smp\folding\1\
  #224 (permalink)
Old June 11, 2009, 11:59 AM
Jon_di2's Avatar
Your internal IP will not work. If thats the # of the one vm ware gives you then it should be \\192.168.1.110\c\etc\folding\1\
make sure you also check the box that states you are running on a virtual machine. Check your cpu usage to ensure that you are in fact folding away just fine and then wait about 20 mins to see if FAH Mon picks it up.
I had trouble with FAH Spy, but FAH Mon picked it up just fine!
\\ 192.168.1.110\c\etc\folding\1\
  #225 (permalink)
Old June 11, 2009, 12:16 PM
SugarJ's Avatar
When I do mine in FAHmon, I put in \\192.168.1.xxx\1, (the IP that VMware assigns to your VM) and tick the VM box. Picks it up no problem. No c\etc\folding at all. When you navigate to the machine via your browser, it tells you where fahlog.txt is.
  #226 (permalink)
Old June 11, 2009, 01:44 PM
Ok I've added 3 different ones, all \\192.168.1.110\different things :)
I'll let it run and see if it picks anything up. The CPU usage is around 90% btw, the rest going to other programs and GPU.
  #227 (permalink)
Old June 11, 2009, 04:05 PM
It still doesn't love me. Any ideas? Also is it normal for VM to say clock source unstable? I looked it up and it appears all that means is my multiplier changed when it loaded (6x to 9.5).
Edit: It seems after letting it run for multiple hours the cpu usage has dropped off completely, I have no idea what's wrong.
  #228 (permalink)
Old June 13, 2009, 07:52 PM
Well it seems to be having difficulty and shuts itself off or something, maybe something isn't stable. I did get fahmon working by using this http://192.168.1.110/1/
  #229 (permalink)
Old June 18, 2009, 12:11 PM
geokilla's Avatar
Is it normal for the Notfred client to slow down your computer by a lot? I'm giving it one FINAL try on my sister's AMD X2 rig, and she says the computer is noticeably slower.
Also for some reason, I can't track its folding progress from my own computer. All my computers are in the same workgroup and using Windows XP.
  #230 (permalink)
Old June 18, 2009, 12:53 PM
chrisk's Avatar
Folding Captain
I only use the Notfred client when not using the rig. I had it set to use the whole processor though. I stopped using the vmware recently to help keep the heat down in the apartment.
What are you using to monitor the vmware machine? You need to use the latest Fahmon (and check the virtual machine check box), and point to the IP address of the virtual machine.
Fold for team #54196
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 08:28 PM
Some help getting VMWare and SMP up and running zlojack HardwareCanucks F@H Team 54 May 3, 2008 10:40 PM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 05:03 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
