Originally Posted by SugarJ Yup, the work stays. I found that the clients always pull the same IP number from my router. It tells you what IP it pulls as it boots, and you set Fahmon or Fahspy to 192.168.1.###/1 (the fahlog is in a subdirectory called 1). |
The IP address I got was 192.168.184.X if I remember correctly, and sometimes it'd give me a different IP then before. Do you know how to set a static IP for it? I PMed Notfred over at Tech Report and he says he doesn't know how to set a Static IP for his Notfred client.
Also, is there a way to force minimize the client to the system tray? If not, I'll just go back to the tried and true Windows SMP.
