Originally Posted by chriskwarren On my Q6600 folding using vmware (used the Evga guide), currently getting 1562 PPD (1920 points, project 2665), and on the other instance of vmware, getting 2464 PPD (also 1920 points, but different project, 2675). 900 PPD difference, but both are configured the same as far as I can tell. Is this due to the project? (using FahSpy). |
The difference is the core used. 2665 is a basic GRO-SMP WU and uses the A1 core and so will fold about the same as under windows. 2675 is a GRO-CVS SMP WU which uses the A2/Linux core and is much more efficient. Don't be surprised if you see widely differing PPD's as the linux client gets both A1 and A2 core WU's, which one you get is luck of the draw same as with the GPU and regular Win/SMP WU's.
The difference in PPD is why so many people want Stanford to hurry up and get the A2 core working on Windows, they keep saying it will happen...someday...
@ zlojack; Sounds like you need an Affinity Setting program, I think they mentioned one somewhere in the thread/guide from ExtremeCPU Forums or check the F@H forums.
@ 3.0charlie; IIRC in one of the threads someone mentioned needing ~640Mb ram for each VM to avoid getting the out of mem error, you might need to upgrade to 64bit...
