  #181 (permalink)
Old May 10, 2009, 04:28 PM
lemonlime's Avatar
Hardware Canucks Reviewer
Not sure if anyone mentioned, but with VMWare player, you can set affinity and priority without third party tools. You just need to edit the folding.vmx file. Here is mine as an example:
This example forces one VM instance to run at idle priority, and use only CPU 0 and 1. My other instance has the same thing, but uses only processor 2 and 3 on my Q6600.
Code:
priority.ungrabbed = "idle"
processor2.use = "FALSE"
processor3.use = "FALSE"
So long as I have my GPU2 client to 'low' priority instead of idle, it doesn't seem to cause any GPU2 ppd issues.
  #182 (permalink)
Old May 10, 2009, 05:02 PM
zlojack's Avatar
lemonlime, do you have to add those lines in, or are they in there already?
[size=3]
  #183 (permalink)
Old May 10, 2009, 05:37 PM
lemonlime's Avatar
They are not there by default. You just add them to the bottom of the file. Just be sure to use an editor like 'Notepad++' to preserve the file formatting.
  #184 (permalink)
Old May 10, 2009, 05:48 PM
zlojack's Avatar
This totally works!
All of you guys who are folding with i7s, use the following at the bottom:
processor0.use = "FALSE"
processor1.use = "FALSE"
processor6.use = "FALSE"
processor7.use = "FALSE"
Then for each instance, just change the processor numbers! Great stuff, lemonline! Thanks for that!
I used Notepad from the Windows 7 Accessories menu for this.
[size=3]
  #185 (permalink)
Old May 10, 2009, 06:05 PM
ImmaPC's Avatar
Well as it turns out setting core affinity doesn't do anything, it just keeps on going with the same results. I'm going to go ahead and switch all the processes back to normal because really the situation hasn't improved.
Rigless. Secret project in the works.
  #186 (permalink)
Old May 16, 2009, 08:22 PM
Silvgearx's Avatar
This is not working out for me i need some instructions that even a chimp can understand
So far i follow the guide from evga and using FAHspy, but its reported as 149 PPD
Ok these were the steps i took.
1.Enable Virtualization on bios,
2.Download VMware 2.5.2 and install
3.downloaded step 2 from the evga guide and extracted folders as "q6600-1" + "q6600-2"
4.open up VMware from the "q6600-1" folder, reconfigure the client to 2 cpus, changed name and team #
5.open fahspy and type in the Fold.XXXX location and fahspy read it as 149PPD
system spec is in sig, with vista ult 32bit
Would i be able to use the GPU2 console for dual GPUs? i can only seem to find guides for the viewer client with 2 GPUs
  #187 (permalink)
Old May 17, 2009, 07:36 AM
3.0charlie's Avatar
Did you reset the clients, as stated in the guide?
As for dual GPU folding, you'd better use the Systray client, and follow this guide: Folding@home - WinGPUGuide. Scroll down to "Installation for a multi-GPU system".
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
  #188 (permalink)
Old May 17, 2009, 07:48 PM
Silvgearx's Avatar
yep it has been reset, thats the only way to let it show on name display and team.
gonna give up cpu folding for now way too much heat
thanks for the link charile
  #189 (permalink)
Old May 30, 2009, 03:04 PM
DAMN! I forgot to edit the memory size and I just lost two WU's that have been crunching all day. :(
heatware
  #190 (permalink)
Old May 30, 2009, 06:21 PM
Silvgearx's Avatar
how to you edit memory? i see no guide in that.
i did not find the mem set in the folder.
Code:
7) Open VMfold-1.vmx with your favorite text editor and make the following 3 changes:
  - change the line:
 memsize = "640"
     to
 memsize = "1152" <------- 1.125GB RAM (the A2 core has a tendency to stall out at the end of WUs if you run less than this)
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 08:28 PM
Some help getting VMWare and SMP up and running zlojack HardwareCanucks F@H Team 54 May 3, 2008 10:40 PM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 05:03 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
