  #171 (permalink)
Old May 10, 2009, 01:09 AM
ImmaPC's Avatar
Confirmed. All four vmware-vmx.exe processes are at low, while GPU processes (F@H and FaHCore_11) are set to Normal.
The 700PPD drop was noticed one hour after re-setting the priorities for the vmware-vmx.exe's while working on the SAME WU as reported by fahspy
Rigless. Secret project in the works.
  #172 (permalink)
Old May 10, 2009, 08:15 AM
3.0charlie's Avatar
The drop is fine, but 4 -vmx.exe processes? I only have 1.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
  #173 (permalink)
Old May 10, 2009, 08:17 AM
zlojack's Avatar
I have four.
[size=3]
  #174 (permalink)
Old May 10, 2009, 08:32 AM
3.0charlie's Avatar
Then I have a problem with Prifinnity 2 then. I did add the -vmx.exe process manually to Low, but the Task Manager does show 4 instances at Normal...
  #175 (permalink)
Old May 10, 2009, 08:40 AM
zlojack's Avatar
Ah sorry, you meant in PriFinnity?
Yeah, in PriFinitty, for whatever reason, I can't set the -vmx processes. I just do it manually in Task Manager.
[size=3]
  #176 (permalink)
Old May 10, 2009, 08:46 AM
3.0charlie's Avatar
Just did so, manually too. 100 point drop per VM, but the 275s gained 600 points each...
  #177 (permalink)
Old May 10, 2009, 08:48 AM
zlojack's Avatar
I also set the core affinity for each one to two cores each.
[size=3]
  #178 (permalink)
Old May 10, 2009, 02:15 PM
ImmaPC's Avatar
Check. Just set core affinity to each -vmx.exe process to two cores each approximately one hour ago. The first VM (i7-1, appears first on the list out of all 4 VM's) is assigned to Core 0, 1, while the next one (i7-2) is set to 2, 3, and so on. No change in PPD noticed as of yet. PPD has risen to normal levels, perhaps due to a new WU.
  #179 (permalink)
Old May 10, 2009, 02:22 PM
Apollo4g's Avatar
Yup im having the same issues, its about trial and error and finding the perfect balance. I have an ATI 4870X2 that needs and uses alot of COU power to fold, about 27% actually, and when i turn on VM ware the PPD goes way down.
I am told that the nvidia cards do not use as much of the CPU, is that true? will a Pen. D be able to handle a 9800GX2 folding?
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
  #180 (permalink)
Old May 10, 2009, 02:40 PM
geokilla's Avatar
It will handle a 9800GTX2 folding. Just make sure you use the latest 18X.XX drivers so the CPU will not be required to feed the GPU core.
Man this thread derails so quickly. But then we get back on topic pretty quick too.
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 08:28 PM
Some help getting VMWare and SMP up and running zlojack HardwareCanucks F@H Team 54 May 3, 2008 10:40 PM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 05:03 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
