  #141 (permalink)
Old May 1, 2009, 04:52 PM
Perineum's Avatar
Oh my, what fun!
Look what I got.....
I've gotten lots of "attempt to access beyond end of device" messages, but....
The line "Clocksource tsc unstable" is brand new. Could it be related to my RAID rebuilding?
  #142 (permalink)
Old May 1, 2009, 05:37 PM
lemonlime's Avatar
Hardware Canucks Reviewer
I believe those 'attempt to access beyond end of device' errors are normal. nofred is working on a fix for that. It doesn't seem to impact my PPD, but I try to give the vmware clients a reboot every few days. Not sure about that clocksource error though. Haven't seen that one yet.
  #143 (permalink)
Old May 1, 2009, 05:45 PM
ImmaPC's Avatar
I get that exact same message on a good number of my VM's from day to day, like lemonlime said it doesn't affect your PPD. I just reboot and be done with it, until it happens again of course. I'm not running a RAID setup and it still happens to me so it's most likely not your RAID config, just a bug probably
Rigless. Secret project in the works.
  #144 (permalink)
Old May 1, 2009, 06:22 PM
geokilla's Avatar
Are you guys folding 24/7 with the Nofred client? Also what's your CPU usage with that client? Mine was at just 90%, 10% short of 100%.
Also, does anyone here turn their machine off when they sleep even though they run the VMWare SMP client? Reason I ask is because I've heard that the VMWare clients don't like it when you shut down and turn it on all the time.
  #145 (permalink)
Old May 1, 2009, 07:35 PM
Perineum's Avatar
I fold with it 24/7. Every machine I own does. It's the only way I can keep up with these crazy farm folding bastards
All 4 cores are at 100%.
My machine never turns off... think of the loss in PPD?!?!!! I listen to a GTX260 with 100% fan and SQUEALING the whole night. It's about 5 feet from my head too.
I'm probably going deaf at the 12000hz and up ranges listening to that
  #146 (permalink)
Old May 3, 2009, 03:07 AM
ImmaPC's Avatar
Mine is absolute 100% usage
I NEVER shut down the client or turn off my machine, unless it's an emergency or a power failure. 24/7/i7, baby!
I get about 6-7K PPD from my i7 alone, although normally its closer to 6K
  #147 (permalink)
Old May 7, 2009, 05:25 PM
dhoshaw's Avatar
Just set up 2 VMs on my Q9550 and combined they are doing 6K PPD.
Intel Q9550 @3.8 GHz
Sapphire 5850 Toxic
XFX 9800GX2
Xigmatek Dark Knight
Gigabyte GA-EP45-UD3P
2 x 2 GB Corsair XMS2 1066C5
2 x WD 640 GB Raid 0 + WD 1 TB
Haf 922 / Antec Signature 850
Windows 7 Ultimate x64
  #148 (permalink)
Old May 7, 2009, 07:02 PM
3.0charlie's Avatar
Whoa, nice ppd for a Q9550.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
  #149 (permalink)
Old May 7, 2009, 08:18 PM
3.0charlie's Avatar
I knew my luck with Vmware would last very long.... on the Folding rig, using Vista Premium 64bit.
Process_Has_Locked_Pages stop: 0x00000076 - BSOD. Removed Vmware, re-installed, re-extracted the original Folding folder, same BSOD. I know Vmware is fine if I start it on its own, the BSOD happens the second I start the VM from the Folding folder.
Googled it, found nothing related to Vista. A few occurences in XP (registry change to know which driver is the culprit, but doesn't work in Vista), but nothing related to that Notfred folding VM. Ran Memtest86, no errors. Raised voltages, same BSOD.
Ideas?
  #150 (permalink)
Old May 7, 2009, 08:28 PM
geokilla's Avatar
Ideas?
Which method of VMware are you using?
Originally Posted by dicecca112
I don't suggest using the reilly site F@H premade Folding VMX. Its not stable, and will crash if you leave it along for extended periods of time
He means that site as the one from EVGA.
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 08:28 PM
Some help getting VMWare and SMP up and running zlojack HardwareCanucks F@H Team 54 May 3, 2008 10:40 PM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 05:03 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
