  #121 (permalink)
Old April 22, 2009, 11:38 AM
LCB001's Avatar
Folding Captain
Originally Posted by Dr_BenD_over View Post
Dell Precision 390 with E6300/2GB/9800GT/XPPro32bit/
That cpu looks a little weak for running the SMP client unless you go the VM route, you might be better off running two uniprocessor clients.
Whichever cpu client you use you will experience the lag if your gpu get's the 511pt WU's, luckily they aren't as common as they used to be...
Folding For Team 54196
  #122 (permalink)
Old April 22, 2009, 05:25 PM
Dr_BenD_over's Avatar
It looks like it just may be too pathetic for 2 clients, I've got the VMWare and a GPU client running on my sig rig under Vista X64 fine, maybe I'll get crazy and see if a second GPU client will run under Vista.
  #123 (permalink)
Old April 22, 2009, 08:12 PM
LCB001's Avatar
Folding Captain
Go for it, you've got a core free might as well use it...
  #124 (permalink)
Old April 23, 2009, 07:52 PM
Ok guys, I'll be needing some help on this one...
Installed Server 2008 x64 on my Q6600 with hyper-V (I thought I'd try that )
In found a utility called VMDK2VHD that converts VMWare VMDK files to VHD then followed instructions on setting up the VM as per the evga guide and everything works up to the reconfiguration step.
At that step, I connect in internet explorer using the VM's IP adress... still no issue but when I go in the reconfiguration page, enter my data then click "Reconfigure" and reset the VM, I find that it did not reconfigure the user, team and memory.
What am I doing wrong?
Gaming rig: P8P67 EVO - i7 2600k - Hyper 212+ - Sniper 4x4GB - GTX460 768MB - Vertex 2 60GB - WD Black 640 GB, TPNew 750W, CM Haf X
DC/Folding server: GA-Z68XP-UD3 - i5 2500 - Ripjaws X 2x4GB - BFG GTX260 - eVGA 9600GSO - Vertex 2 60GB - Seagate 7200.12 1TB
Aeacus: KGPE-D16, 2x6128 - 2xNH-U9D0 - 8x4Gb Corsair - PERC 5i 512MB - Xigmatek Elysium - Intel 320 Series 80 GB - 4x Seagate 7200.12 1TB - TP Quattro 850W
  #125 (permalink)
Old April 23, 2009, 08:18 PM
Perineum's Avatar
I've got a question, and I hope it's not a stupid one....
Is there a way to minimize my 2 vmware windows to my system tray? Right now they sit in my task bar and it's annoying to look at.
  #126 (permalink)
Old April 23, 2009, 08:54 PM
zlojack's Avatar
I use the MinimizeToTray app and that sends anything I want to the system tray.
mozdev.org - minimizetotray: index
[size=3]
  #127 (permalink)
Old April 23, 2009, 11:29 PM
Perineum's Avatar
Which one of those do I actually download? I don't use any of the listed applications....
  #128 (permalink)
Old April 24, 2009, 06:10 AM
zlojack's Avatar
Uhm...I was a bit drunk last night
Hold on and let me see if I can find the app I use
EDIT: http://minimizetotray.com/
That's better...
[size=3]
  #129 (permalink)
Old April 24, 2009, 11:46 PM
ImmaPC's Avatar
@Zlojack:
Tried out that suggestion about turning down the memory ratio, and then I just used that BIOS template you gave me. The folding has improved vastly, however I NEED to get this cheque cleared ASAP so I can buy 3.0Charlie's TRUE 120 because the i7 is (according to CoreTemp) hovering around 100C, which is...bad...
Should I stock-clock it or let it go for tonight?
EDIT: The MB LCD thingie reads 84C, and has read that constantly for the last couple've hours. Meanwhile CoreTemp says that heat is off the charts. Which one should I believe?
Rigless. Secret project in the works.
  #130 (permalink)
Old April 24, 2009, 11:56 PM
zlojack's Avatar
Originally Posted by ImmaPC View Post
@Zlojack:
The LCD is just the temp of the IHS. Believe CoreTemp. I suggest you back it down until you get better cooling.
[size=3]
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 08:28 PM
Some help getting VMWare and SMP up and running zlojack HardwareCanucks F@H Team 54 May 3, 2008 10:40 PM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 05:03 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
