  #91 (permalink)
Old April 18, 2009, 07:37 PM
geokilla's Avatar
Originally Posted by geokilla View Post
You're running VMware? My E7200 @ 3.7Ghz gets around 1500PPD atm. Max I've seen was 2000PPD on the 1760 point WU.
Anyone managed to get VMware Folding setup as a service client? By service, I mean the WHOLE thing as a service.
No one?
@Imma. He might've gotten the A2 cores. Those fold significantly faster than the A1 cores.
@3.0 and Chris. Mind sharing what's going on with the screenies? I'm not getting what's going on...
  #92 (permalink)
Old April 18, 2009, 07:39 PM
3.0charlie's Avatar
Chris couldn't find the -vmx file for Prifinitty, since he wasn't looking into the correct folder...
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
  #93 (permalink)
Old April 18, 2009, 07:48 PM
chrisk's Avatar
Folding Captain
No one?
Pebkac. ID 10 T error. Basically, I wanted to set the priorities automatically using prifinity, and went looking for it in the standard install folders. Problem was , I did not install it in the standard folder, hence why I could not find it....
Time to move along folks, nothing to see here...
Fold for team #54196
  #94 (permalink)
Old April 18, 2009, 08:46 PM
zlojack's Avatar
Here's how it shows on my 32bit rig. And Jack, a glimpse of the i7 ppd.
Crazy man! I'm set up pretty much the same, but I don't get anywhere near that PPD. Could it be that I have to install VMWare somewhere other than Program Files?
I'm still at about 1800 per.
I wonder if Prifinitty has some issues with 64 bit Vista.
[size=3]
  #95 (permalink)
Old April 18, 2009, 08:47 PM
3.0charlie's Avatar
Vmware is installed on my secondary drive, actually. And we'll know in a week if 64 bit is an issue....
  #96 (permalink)
Old April 18, 2009, 08:50 PM
zlojack's Avatar
Hmm...well I'm disinclined to go through the whole reinstall process right now.
I'll leave it as is and wait it out.
When I get another SSD and have to resinstall, I'll do it then. I might jump over to Win7, though, since it looks like SLI is working now.
[size=3]
  #97 (permalink)
Old April 18, 2009, 10:23 PM
ImmaPC's Avatar
Great...so I just *slightly* OC'ed my i7 920 with a BCLK of 150mhz, meaning 3ghz. I didn't bother stepping up voltage, perhaps I ought have but I decided against it, I'm really nervous about i7 OCing...
Well the sytem POSTed but it didn't boot. Windows didn't like the OC. It said that there was a driver problem with "acpi.sys" or something or other. I even set it to "Dummy OC" to see if I did something wrong and Windows did the same thing. Damn, so close but so far. It posted but now windows...wtf did I do wrong?!? >.>
How can I tell what core I have? (A1/A2) Can I check with CPU-Z?
Rigless. Secret project in the works.
  #98 (permalink)
Old April 18, 2009, 10:41 PM
LCB001's Avatar
Folding Captain
A1/A2 are SMP Folding cores. They have nothing to do with your OC.
A1 is the old SMP core used by Windows and Linux, A2 is the newer faster SMP core that can be used by the Linux client only. To find out which one your WU is using , check the log.
Folding For Team 54196
  #99 (permalink)
Old April 18, 2009, 10:56 PM
chrisk's Avatar
Folding Captain
I am getting 2100PPD per instance of vmware on my Q6600 on Vista 64-bit. The Q6600 is OCed to 3.0GHZ.
My vmware is not running in the Program Files directory (I try not to run any F@H stuff on Vista in the Program Files dir...
  #100 (permalink)
Old April 18, 2009, 11:07 PM
ImmaPC's Avatar
It said "Downloading FAH_core_a2.exe" XD A2 Core! Wohoo! Still though, why does windows not like my OC?
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 08:28 PM
Some help getting VMWare and SMP up and running zlojack HardwareCanucks F@H Team 54 May 3, 2008 10:40 PM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 05:03 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
