-   HardwareCanucks F@H Team (https://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   How to change F@H teams on a PS3 (https://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/16026-how-change-f-h-teams-ps3.html)
Barber March 21, 2009 08:02 AM
Hey All,
I want to change my PS3 to fold for HWCs how do I do this?? I've followed tons of guides online and they all say click on Identities... I don't have this button.. I'm using the newest version of PS Life, recently dl'ed the new upgrade.
Thanks guys!!
Mr. Gruntsworthy March 21, 2009 09:06 AM
In the folding channel, press Triangle to bring up the options. Go to Current Channel >> Identity.
'Join an existing team' will let you set the team you are folding for (HWC is team 54196).
'Change Donor Name' will let you set it to your F@H username so the PS3 F@H points accumulate on your account.
:P hope I helped :)
chrisk March 21, 2009 09:15 AM
Welcome to the team!
Barber March 22, 2009 10:08 AM
That identity option is not there. I read all the online guides, they say the same thing, It's just not there.
chrisk March 22, 2009 10:28 AM
I can access the team/user info by doing the following (assuming you have your system fully updated):
1. Enter the Life with Playstation
2. Enter the folding at home channel. You will see a map of the world with green dots that identify PS3s that are folding.
3. Press Triangle
4. Select "Current Channel"
5. Select "Identity"
Here you will see "Change Donor Name", and "Join an Existing Team". Enter your folding name under the 'Donor Name' option, and team 54196 in the "Existing Team" option.
Hope this helps! If your options are nothing like mine suggested above make sure you have Life with Playstation installed, as the folding application was integrated with that program. This was not the case when the PS3 was first shipped.
chrisk March 28, 2009 10:32 PM
Hey Barber;
I just put together a guide on how to change the identity on a PS3. Take a look at it and see if it helps you if you are still having issues.
