Old March 14, 2009, 01:30 PM
Alwaysrun's Avatar
Default GPU crash. Not sending results
Sigh just when I thought everything was going swimingly.
I heard my Computer restart for some unknown reason. It has just finished a WU and was about to sent the results but never did. Heres the log in case anyone has an idea how I can fix this.
Code:
[19:39:22] Completed 100%
[19:39:22] Successful run
[19:39:22] DynamicWrapper: Finished Work Unit: sleep=10000
[19:39:32] Reserved 34600 bytes for xtc file; Cosm status=0
[19:39:32] Allocated 34600 bytes for xtc file
[19:39:32] - Reading up to 34600 from "work/wudata_00.xtc": Read 34600
[19:39:32] Read 34600 bytes from xtc file; available packet space=786395864
[19:39:32] xtc file hash check passed.
[19:39:32] Reserved 23472 23472 786395864 bytes for arc file=<work/wudata_00.trr> Cosm status=0
[19:39:32] Allocated 23472 bytes for arc file
[19:39:32] - Reading up to 23472 from "work/wudata_00.trr": Read 23472
[19:39:32] Read 23472 bytes from arc file; available packet space=786372392
[19:39:32] trr file hash check passed.
[19:39:32] Allocated 560 bytes for edr file
[19:39:32] Read bedfile
[19:39:32] edr file hash check passed.
[19:39:32] Allocated 252083 bytes for logfile
[19:39:32] Read logfile
[19:39:32] GuardedRun: success in DynamicWrapper
[19:39:32] GuardedRun: done
[19:39:32] Run: GuardedRun completed.
--- Opening Log file [March 14 19:43:23 UTC]
# Windows GPU Console Edition #################################################
                       Folding@Home Client Version 6.23
                          Folding@home - Main
Launch directory: C:\Users\Alwaysrun\AppData\Roaming\Folding@home-gpu
Arguments: -advmethods
[19:43:23] - Ask before connecting: No
[19:43:23] - User name: Alwaysrun (Team 54196)
[19:43:23] - User ID: 11E5F9EB69C7972B
[19:43:23] - Machine ID: 2
[19:43:23]
[19:43:23] Loaded queue successfully.
[19:43:23] Initialization complete
[19:43:23]
[19:43:23] + Processing work unit
[19:43:23] Core required: FahCore_14.exe
[19:43:23] Core found.
[19:43:23] Working on queue slot 00 [March 14 19:43:23 UTC]
[19:43:23] + Working ...
[19:43:24]
[19:43:24] *------------------------------*
[19:43:24] Folding@Home GPU Core - Beta
[19:43:24] Version 1.24 (Mon Mar 2 19:49:32 PST 2009)
[19:43:24]
[19:43:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:43:24] Build host: vspm46
[19:43:24] Board Type: Nvidia
[19:43:24] Core      :
[19:43:24] Preparing to commence simulation
[19:43:24] - Ensuring status. Please wait.
[19:43:33] - Looking at optimizations...
[19:43:33] - Working with standard loops on this execution.
[19:43:33] - Created dyn
[19:43:33] - Files status OK
[19:43:33] Error: Missing work file=<>
[19:43:33]
[19:43:33] Folding@home Core Shutdown: MISSING_WORK_FILES
[19:43:36] CoreStatus = 74 (116)
[19:43:36] The core could not find the work files specified. Removing from queue
[19:43:36] Deleting current work unit & continuing...
[19:43:40] - Preparing to get new work unit...
[19:43:40] + Attempting to get work packet
[19:43:40] - Connecting to assignment server
[19:43:41] - Successful: assigned to (171.64.122.70).
[19:43:41] + News From Folding@Home: GPU folding beta
[19:43:41] Loaded queue successfully.
[19:43:43] + Closed connections
[19:43:48]
[19:43:48] + Processing work unit
[19:43:48] Core required: FahCore_14.exe
[19:43:48] Core found.
[19:43:48] Working on queue slot 01 [March 14 19:43:48 UTC]
[19:43:48] + Working ...
[19:43:48]
[19:43:48] *------------------------------*
[19:43:48] Folding@Home GPU Core - Beta
[19:43:48] Version 1.24 (Mon Mar 2 19:49:32 PST 2009)
[19:43:48]
[19:43:48] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:43:48] Build host: vspm46
[19:43:48] Board Type: Nvidia
[19:43:48] Core      :
[19:43:48] Preparing to commence simulation
[19:43:48] - Looking at optimizations...
[19:43:48] - Created dyn
[19:43:48] - Files status OK
[19:43:48] - Expanded 68530 -> 357580 (decompressed 521.7 percent)
[19:43:48] Called DecompressByteArray: compressed_data_size=68530 data_size=357580, decompressed_data_size=357580 diff=0
[19:43:48] - Digital signature verified
[19:43:48]
[19:43:48] Project: 5903 (Run 6, Clone 56, Gen 2)
[19:43:48]
[19:43:48] Assembly optimizations on if available.
[19:43:48] Entering M.D.
[19:43:54] Tpr hash work/wudata_01.tpr:  111044202 3927793253 2944239816 3299118797 2433444812
[19:43:54] Working on Protein
[19:43:55] Client config found, loading data.
[19:43:55] Starting GUI Server
[19:46:26] Completed 1%
[19:39:32] Run: GuardedRun completed. was where it crashed.
Argg when I looked in the work folder the only out of place file I see is wuresults_00.dat at 64k. Theres also the ussual files associated with the WU I'm now working on all named *_01.dat ect. where the heck did the results go for my last WU? can I retrieve them somehow with a program like Qfix or are they in a temp folder in Vista? I can't lose a finished 1680 pointer!!!
Ohh and the one that failed to send in it's results just happens to be the exact same WU I got again upon the restart from that crash. Project: 5903 (Run 6, Clone 56, Gen 2)
Old March 14, 2009, 09:15 PM
LCB001's Avatar
Folding Captain
Qfix might be able to help but if the Run/Clone/Gen on the new WU are the exact same as the old one it looks like you are out of luck, it sounds like the WU got corrupted. If you think it might still be there you can try adding the '-send x' flag (x = queue slot #) to the end of your shortcut and restarting the client, but I doubt it will help. If you do use the flag don't forget to delete it after.
It looks like your reboot was at the one time the client can't recover from, ouch...
Edit/ Double check your stats, it might have sent it in automatically when it restarted...
Folding For Team 54196
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 08:57 AM
crash time 2 burning wheels cmac79 Gaming 0 January 5, 2009 06:38 AM
Linux first to crash :( Shadowed O/S's, Drivers & General Software 5 September 10, 2007 07:01 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 12:52 PM
Vista Crash?? Marzguitarz CPU's and Motherboards 5 February 3, 2007 11:53 PM
