  #31 (permalink)
Old February 27, 2009, 01:25 PM
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.23 Beta R1
Folding@home - Main
Launch directory: C:\FAH
Executable: C:\FAH\FAHE8400.exe
Arguments: -smp -smp -verbosity 9
[20:23:15] - Ask before connecting: No
[20:23:15] - User name: cashekicker (Team 54196)
[20:23:15] - User ID:
[20:23:15] - Machine ID: 1
[20:23:15]
[20:23:15] Loaded queue successfully.
[20:23:15]
[20:23:15] + Processing work unit
[20:23:15] - Autosending finished units... [February 27 20:23:15 UTC]
[20:23:15] Trying to send all finished work units
[20:23:15] + No unsent completed units remaining.
[20:23:15] - Autosend completed
[20:23:15] Work type a1 not eligible for variable processors
[20:23:15] Core required: FahCore_a1.exe
[20:23:15] Core found.
[20:23:15] Using generic mpiexec calls
[20:23:15] Working on queue slot 01 [February 27 20:23:15 UTC]
[20:23:15] + Working ...
[20:23:15] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -cpu 90 -checkpoint 15 -verbose -lifeline 1208 -version 623'
[20:23:15]
[20:23:15] *------------------------------*
[20:23:15] Folding@Home Gromacs SMP Core
[20:23:15] Version 1.74 (March 10, 2007)
[20:23:15]
[20:23:15] Preparing to commence simulation
[20:23:15] - Ensuring status. Please wait.
[20:23:32] - Looking at optimizations...
[20:23:32] - Working with standard loops on this execution.
[20:23:32] - Previous termination of core was improper.
[20:23:32] - Going to use standard loops.
[20:23:32] - Files status OK
[20:23:36] - Expanded 2409335 -> 12894661 (decompressed 535.1 percent)
[20:23:36]
[20:23:36] Project: 2653 (Run 36, Clone 26, Gen 119)
[20:23:36]
[20:23:37] Entering M.D.
[20:23:43] Calling FAH init
[20:23:44] in POPC
[20:23:44] Writing local files
[20:23:44] checkpoint)
[20:23:44] Read checkpoint
[20:23:45] 0 steps (37 percent)
[20:23:45] Extra SSE boost OK.
[20:23:45] es
[20:23:45] Completed 185000 out of 500000 steps (37 percent)
[20:23:46] Extra SSE boost OK.
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
  #32 (permalink)
Old February 27, 2009, 01:31 PM
LCB001's Avatar
Folding Captain
Originally Posted by CasheKicker View Post
Ok so how do I get it running a client for each core. Any special trick to that?
Oh and I am getting 1460.5ppd right now with 37% complete. Been running for 11 hrs now.
You don't need another client, the SMP client is designed to use more than one core.
Looking at the new log file it's completing a step every 17min, which sounds about right. It should be using both cores now.
Folding For Team 54196
  #33 (permalink)
Old February 27, 2009, 01:40 PM
Cool. Thats great to here and infact both cores are working away.
I guess next I need to OC this puppy. Still running at stock and my RAM is underclocked.
But then again I may not. Would that be a crime??
  #34 (permalink)
Old February 27, 2009, 01:48 PM
LCB001's Avatar
Folding Captain
Well, it's free ppd there for the taking. On the other hand is whatever you are comfortable with is good.
It's better to Fold slowly than to not Fold at all...
  #35 (permalink)
Old February 27, 2009, 01:58 PM
Well my total PPD right now is hitting 12000, which puts me well into the teams top 10, Son't think I am folding slowly... Just want more, more, more...
Need my 15000ppd fix now!!!
  #36 (permalink)
Old February 27, 2009, 02:10 PM
LCB001's Avatar
Folding Captain
Good, another one Hooked...
When I said Folding slowly was better than nothing I meant in terms of overclocking the CPU client, not your overall PPD ...
It feels good being in the top 10 ppd, top 5 feels even better...
  #37 (permalink)
Old February 27, 2009, 02:13 PM
Hmmmm, still have that empty PCI-e x16 slot just looking at me... Hmmmmmm..............!!!!!!!!!!!!
  #38 (permalink)
Old February 27, 2009, 02:56 PM
LCB001's Avatar
Folding Captain
Be a shame to let that go to waste...
  #39 (permalink)
Old February 27, 2009, 05:18 PM
Grrrr....
Ok I decided to OC the rig just a bit. Have the E8400 running stable at a cool 450X8 for a 3.6Ghz.
However when I went to fire up my SMP client I am getting errors. I really dont want to delete folders and start over as I was already at 45% after 15hrs of crunching...
It refuses to connect and suggest I run install.bat again, when I do that I get
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to "my computer" on port 8676
, exhausted all endpoints (errno -1)
, no connection could be made because the target machine actively refused it (errno 10061)
Press any key to continue . . .
C:\fah>
  #40 (permalink)
Old February 27, 2009, 05:24 PM
Jake_HT's Avatar
Jeez and I thought the SMP client didn't like me....
http://jakeht.deviantart.com/
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
What F@H client are you using? Silvgearx HardwareCanucks F@H Team 8 February 7, 2009 09:51 AM
New Members Folding with Nvidia/Ati Gpu 2 Client/ Some Tips Dashock HardwareCanucks F@H Team 43 January 4, 2009 03:39 PM
Folding using the Nvidia Client? Heres some Tips Dashock HardwareCanucks F@H Team 90 September 14, 2008 06:28 PM
