Originally Posted by BT! i'm using CPU client 6.23, but for some reason on my second PC (q6600) its mainly using core 2. my main rig with the e8400 seems to be using both atm but i have seen it where its only using the 2nd core aswell. is this normal?
Main rig
HAF 932 Case
EVGA 780i
E8400 @ 3.6GHz w/ Lapped TRUE 120
EVGA GTX260 Core 216 SC
4GB OCZ Platnum DDR2
Antec TPQ 850w
Vista Ultimate 64Bit
Second Rig
NZXT Hush Case
XFX 680i
Q6600 @ 3.0GHz
XFX 8800GT XXX Edition
XP Pro 32bit |
If you are using the standard CPU client it is designed to run on one core. To use more cores you need to run multiple instances of the client or use the SMP CPU version...
