Old February 5, 2009, 10:27 PM
zlojack's Avatar
Default Can someone help me set up folding on my SLI?
I think I'm probably just too tired to figure it out but does someone have a "For Dummies" sort of guide for getting folding on two GPUs?
I thought I'd done it right but apparently I failed.
Thanks for any help
Cheer!
(I do know that you need SLI disabled and you need to have two separate folders for the client)
Old February 5, 2009, 10:52 PM
LCB001's Avatar
Folding Captain
Did you follow a guide, this is a good one [H]ard|Forum - View Single Post - [H]orde Guides
What type error are you getting?
Folding For Team 54196
Old February 6, 2009, 01:06 AM
I didn't think folding in SLI worked. I thought you had to turn it off then add a -gpu 0 and -gpu 1 to the command line of 2 clients.
Old February 6, 2009, 06:12 AM
zlojack's Avatar
Hence why I said in my post that I know you need to disable SLI to fold
I'll check that guide out this evening with a more clear head. Thanks guys.
Old February 6, 2009, 07:44 PM
zlojack's Avatar
Alright, looks like I'm good to go. Thanks again guys!
Old February 6, 2009, 07:51 PM
LCB001's Avatar
Folding Captain
Good stuff !! glad you got it sorted out, what was the problem, one of the shortcuts ?.
I would be interested in what sort of PPD you get on the different WU's with those beasts , especially the 511's...
Old February 6, 2009, 07:54 PM
zlojack's Avatar
FAHMon says I'm getting a total of about 12500 right now.
Project is 5755
Old February 6, 2009, 08:34 PM
chrisk's Avatar
Folding Captain
Is that a 511 point WU? Looks pretty good to me. Have you tried OCing the shaders yet?
Fold for team #54196
Old February 6, 2009, 08:35 PM
LCB001's Avatar
Folding Captain
Project is 5755
5755 is a 511pt WU, rare bad luck to get the same project on both cards, normally they are different. Have you had a chance to crank the shaders yet and see what they'll do ??...
Old February 6, 2009, 09:06 PM
zlojack's Avatar
Could it be because I copied the directories?
I can't crank the clocks very high on these cards yet. I'm still waiting on waterblocks.
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
Folding a la GTX 285 SKYMTL HardwareCanucks F@H Team 23 February 24, 2009 12:43 AM
Folding on the PS3? wpurcell HardwareCanucks F@H Team 4 January 1, 2009 02:45 PM
Folding Through A VPN?? Soultribunal HardwareCanucks F@H Team 12 December 23, 2008 01:07 PM
GTX 280 Now Folding for HCF SKYMTL HardwareCanucks F@H Team 26 June 17, 2008 01:23 PM
