Old February 6, 2009, 06:33 AM
Eagle Eye's Avatar
Thanks Chris worked perfectly, much appreciated.
EE
Old March 16, 2009, 02:09 PM
stoanee's Avatar
Is there a way of monitoring folding done with linux & virtual machine under windows?
heatware
Old March 16, 2009, 02:22 PM
chrisk's Avatar
Folding Captain
You would have to share the folder in which the work files are located in your virtual machine. However I have not done this on Linux or a virtual machine. I know a couple of members here have tried folding on Linux, and would know more than I.
Fold for team #54196
Old March 16, 2009, 02:38 PM
3.0charlie's Avatar
(from my Ubuntu crib sheet)
system->administration->shared folders
The first time you go down this path you will be prompted to download and install sharing software ... since my main rig is wxp, i leave samba selected and deselect nfs.
Once it downloads and install samba then you can continue ( no reboot necessary)
add your home folder and deselect 'read only' checkbox so you can copy to this from another machine - leave read only if you prefer since it is good enuf for fahmon.
I also select general properties and change the domainname to 'WORKGROUP' since this is my default domain on my WXP rigs. If you use WXP home then i expect the default MSHOME is good for you.
now open a terminal window: applications->accessories->terminal
in the terminal window type : 'sudo smbpasswd -a [username]' and then you will have to enter your password once for the sudo override to authenticate you, and then twice more for the smbpasswd command.
You should now be able to share files with all your other rigs. For convenience i use the same userid and password on all my wxp and linux installs.
Old April 6, 2009, 04:12 PM
Silvgearx's Avatar
Hey chris, you might want to add, how to used FAHmon for the console version too, it took me at least a hour googling to find out that you select the whole folders for it to show PPD for the console version
Old April 6, 2009, 04:36 PM
chrisk's Avatar
Folding Captain
Thanks for the suggestion. I thought I mentioned it in the folders section of the first post. I'll quote it below:
The above directories are for the "System Tray" client. If you installed the Console client (when you run it you see a small black "Dos" like window), you need to point FahMon to the folder in which you downloaded and ran the Folding@home console client. This could be anywhere on your computer. For example, if you are like me, you may have put this download on your "Desktop". In that case, you would have to point FahMon to C:\Users\(yourusername)\Desktop\Folding@home-Win32-x86-623
If you use the SMP beta client, and used Xilikon's excellent guides on the FaH site or [H]ordeguides, you should point FahMon to C:\FAH . This is a suggested folder, especially in Vista, to avoid permissions issues.
Was the above quote what you mean?
Old April 6, 2009, 04:40 PM
Dashock's Avatar
Well done should make it easier for new-comers its a little tricky i remmeber i was trying to set it all up. Well done.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old April 6, 2009, 05:14 PM
Silvgearx's Avatar
  #19 (permalink)
Old April 15, 2009, 05:23 PM
Jon_di2's Avatar
thanks this was great! Just setting up now!
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
  #20 (permalink)
Old April 15, 2009, 05:27 PM
chrisk's Avatar
Folding Captain
NP! Hope any new folders who join for the contest find it useful.
Tags
fah , fahmon , folding , folding @ home , hfm.net , setup , tutorial , videos
Folding @ Home F.A.Q. Supergrover HardwareCanucks F@H Team 229 May 15, 2010 08:24 PM
How you setup the Big ADV in HFM.net MarkOne HardwareCanucks F@H Team 1 January 23, 2010 03:01 PM
FAHMon to monitor other computer's folding? Lpfan4ever HardwareCanucks F@H Team 4 November 13, 2009 10:06 AM
FAHMon and F@H set up reccomendations CasheKicker HardwareCanucks F@H Team 36 February 22, 2009 04:57 PM
Can someone help me set up folding on my SLI? zlojack HardwareCanucks F@H Team 27 February 16, 2009 04:25 AM
