  #21 (permalink)
Old February 18, 2009, 12:36 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Adjust 1 thing at a time, you cant say mem makes a diff when you are adjusting core mem and shaders together. Core increase will give a slight PPD boost, mem as well to a lesser extent. Shaders give huge PPD boost.
  #22 (permalink)
Old February 22, 2009, 09:03 AM
Well after almost a week of tweeting this is what I have found to be my most efficient clocks. With this setup I am very stable and get my highest PPD. The bonus to this is when playing I found depending on where my clock were set I would start to get the high pitch noise described by many with these cards. However, when I am running these speeds the sound virtually disappears.
650C/1650S/1350M with fans at 50% temps read 73deg C with this I am getting 8700-9242ppd on the 353 WU, 8500-9479ppd on the 384 WU and around 6898 - 7237ppd with the 511WU.
Not to sure how that compares but it is what I am getting.
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
  #23 (permalink)
Old February 22, 2009, 04:01 PM
chrisk's Avatar
Folding Captain
Thanks cashe. My 285 will be here in just over a week hopefully. If the card does not squeal too much I might try to get the shaders a little higher. I'll post when I figure my future card out.
Fold for team #54196
  #24 (permalink)
Old February 23, 2009, 11:43 PM
Dashock's Avatar
I have put both my Memory and Core down several times in incriments of 100-200 and have found little/no difference in PPD. This is with my 8800GT, if there was a difference it was so small that it could have been because i was using the computer with applications at the time. Shader clock seems to be the only thing that effects your ppd. As for temperature im not sure as the most i have ever gotten this card to is 40 degrees. BTW i have also underclocked my cpu i did this testing awhile back and posted a thread, when folding i have my stock Xeon E3110 from 3.0ghz to 1.6ghz-1.4ghz and still see little to no impact on the ppd. Save yer money and just overclock the crap outta the Shaders. Also i think decreasing the core and memory might give you a boost in the Shaders.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Folding on the PS3? wpurcell HardwareCanucks F@H Team 4 January 1, 2009 01:45 PM
Folding Through A VPN?? Soultribunal HardwareCanucks F@H Team 12 December 23, 2008 12:07 PM
Catalyst 8.12 folding Alwaysrun HardwareCanucks F@H Team 1 December 10, 2008 07:37 PM
CPU folding BT! HardwareCanucks F@H Team 9 December 2, 2008 10:20 PM
GTX 280 Now Folding for HCF SKYMTL HardwareCanucks F@H Team 26 June 17, 2008 01:23 PM
