Old January 6, 2009, 05:03 PM
Default Best way to fold on a quad core?
What's the best client to use that will make the most of my Q6600? I tried the SMP client but it still only uses 25%-50% of the processor, even if it was idle. The SMP client also requires that I have a password on my windows account, which I don't really want. Can I run four instances of the regular console client at once?
Old January 6, 2009, 05:13 PM
3.0charlie's Avatar
I would use BOINC and Rosetta with your Quad, if you do not want any passwords on your Win account.
Hydro-Quebec is salivating...
Old January 6, 2009, 05:34 PM
geokilla's Avatar
Run the F@H Affinity changer along with two SMP clients. That will use 100% of your CPU.
Don't forget to GPU fold as well. If you're using NVIDIA, the new 180 and after drivers require little to no CPU overhead in order to fold on the GPU.
Old January 6, 2009, 05:40 PM
LCB001's Avatar
Folding Captain
The SMP 6.23R1 client should have been using up to 100% of your quad, are you sure you installed it right?. In task manager it should show as four instances of FahCore_a1.exe*32 with each instance at up to 25%, one instance per core. You could run four instances of the classis client which might be easier for you, they just need different machine ID's.
I don't find the password annoying but mine run 24/7 and I only use it after they are stopped for cleaning, If you don't like a password your better off with Boinc like 3.0charlie recommended...
Folding For Team 54196
Old January 6, 2009, 05:56 PM
Okay, I managed to get the SMP client working. Apparently I had to run it with the -smp argument Can I GPU fold as well when I'm running the SMP client? I have an ATI card, I'm not sure how much CPU the ATI client uses.
Old January 6, 2009, 06:00 PM
LCB001's Avatar
Folding Captain
That sometimes happens. You're not supposed to need it anymore but it some times downloads the wrong WU on start-up and uses the wrong core. Glad you got it going.
Welcome to the Fold...
Edit; You can use the GPU at the same time , just make sure it has its priority set slightly higher.
Old January 6, 2009, 07:49 PM
chrisk's Avatar
Folding Captain
Welcome to the team Matt! If you're folding for HWC don't forget to ask for a tag.
Fold for team #54196
Intel Core 2 Quad Q8200 vs Intel Core 2 Duo E8500 Hanibal{CA} New Builds 18 August 10, 2009 07:53 PM
Some help with a quad core build? DRYJESUS New Builds 16 December 24, 2008 09:23 PM
[WTB] Intel Quad Core CPU chouchou Buy/Sell & Trade 3 November 26, 2008 11:38 PM
WTB/WTT: LGA775 Quad Core/Dual Core Chilly Buy/Sell & Trade 7 November 11, 2008 12:46 AM
How to fold with a quad? Apollo4g HardwareCanucks F@H Team 34 October 30, 2007 07:45 AM
