<~----> How well can an.. - Hardware Canucks
Old December 23, 2008, 02:36 PM
Infiniti's Avatar
Default How well can an..
E6420 fold? I recently got a free mobo, (P35-DS3R) and I had the chip laying around. Do you think it can do much? Or will it generate too much heat and take up too much power?
Old December 23, 2008, 02:37 PM
sswilson's Avatar
I ran one until it fried (water cooling leak). They do fairly well due to the extra cache.
3.0charlie's Avatar
I would definitely try BOINC, instead of F@H on this chip.
Old December 23, 2008, 02:52 PM
Infiniti's Avatar
Okay, but will stock cooling (for 45nm) work? Thats what I have on it right now, but the idle temps are around 25.
Old December 23, 2008, 02:57 PM
3.0charlie's Avatar
Keep a close eye on those temps.
Old December 23, 2008, 03:12 PM
Chilly's Avatar
You mean one of those "slim" heatsinks that came stock with the E8400? If so, it MAY work, but I'd keep a DAM close eye on the temps.
Old December 23, 2008, 03:17 PM
Infiniti's Avatar
Yeah, thats the one I'm talking about. But so far, it seems to be doing okay, maxing out at around 50.
I might put it under water though, to see how far I can OC this..
Old December 23, 2008, 03:30 PM
Chilly's Avatar
Sounds like it should be okay then.. I'd still keep eye on it regardless. What happened to your E8400(your signature)? Did I miss the thread?
Old December 23, 2008, 03:40 PM
Infiniti's Avatar
No, you didn't miss a thread, but I probably should of posted one..
But yeah, I was playing around with a friend of mine with some DI, and we were using his E2180, and we got it pretty far. Since we then had experience, we put in my E8400 chip, again, we got it pretty far, but this time, condensation caused water to get into the socket, frying the chip and the board.
Lesson learned. Use better insulation.. Electrical tape doesn't work well.
Old December 23, 2008, 04:30 PM
LCB001's Avatar
Folding Captain
If you could get a half decent Nvidia card in there you could help both the F@H and Boinc teams, and have a good start on a Foldng Farm...
Folding For Team 54196
