-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   Rosetta @ Home - Setup Guide (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/13086-rosetta-home-setup-guide.html)
Chilly December 20, 2008 01:32 PM
Alright then, I've seen this asked many times, and it seems that there is no simple to follow guide out there. While setting up BOINC is relatively painless and easy, there still seems to be some who need a bit of help on how its properly done. So I decided to create an easy step by step guide(with photos!) for all interested, but not yet crunching members.
Being this easy, theres no excuse not to crunch! :canadianwave:
Lets get started.
First download and install BOINC from here
http://www.ndesk2.net/images/1.jpg
Once finished, just run the installer, and follow the on screen instructions. Leave everything at their default settings. Once finished you will get a warning that you need to restart, hit finish and then Ok/Yes to restart. Ensure your ready to restart beforehand
http://www.ndesk2.net/images/2.jpg
Once restarted, you will be greeted with a window that looks like this, just hit next
http://www.ndesk2.net/images/4.jpg
After a second or 2, a list of all available projects will be presented to you, just scroll down until you find Rosetta@home, then select it, and hit next
http://www.ndesk2.net/images/5.jpg
Now its going to ask you if you have a user account or not, I will assume for the purpose of this guide, that you do not. Simply fill in your email address and input a password of your choosing
http://www.ndesk2.net/images/20.jpg
So now your done installing it! Hit finish and lets get on with the next step, adding a team!
http://www.ndesk2.net/images/6.jpg
After you hit finish it will automatically bring you to this web page, just fill in the information however you'd like and hit ok
http://www.ndesk2.net/images/7.jpg
Okay, so now it will bring you to this page where you can search for a team to add, simple fill in the information like below for the HardwareCanucks team :canadianwave:
http://www.ndesk2.net/images/8.jpg
Once you hit search it should bring up something like this, if you filled out the information as above HardwareCanucks should be first, simple select/click in the name to go forward
http://www.ndesk2.net/images/9.jpg
It should now bring you to this page, simply select/click "Join this team"
http://www.ndesk2.net/images/10.jpg
Your now done! You've joined the HardwareCanucks team! It will bring you to your account information page, feel free to change or fix anything here, such as your preferences, profile and etc
http://www.ndesk2.net/images/11.jpg
Now that your done, you can leave it at that, but we don't like leaving things alone now do we? :haha: Hit "Advanced View" at the bottom right of the manager
http://www.ndesk2.net/images/12.jpg
It should now change into this(IMO better) view in which you have much more control at your fingertips. Feel free to look around, there's some interesting things to be had and seen here, but the main tab we will be looking at today is the "Tasks" tab. This will show you what your working on, how many jobs you have queued, if any of them failed, etc.
http://www.ndesk2.net/images/13.jpg
Now that your done playing around, go to Advanced and then Preferences
http://www.ndesk2.net/images/14.jpg
It will bring you to this, or similar window. What follows next are, and I do stress, are NOT REQUIRED, but rather RECOMMENDED settings to change. First of all go to the Network Usage tab, and change the Additional work buffer to something larger, most of us here have it set to 3 or more days. One note I must make though is that if your computer is not on much(such as a laptop), or a slower computer(Pre-P4/AXP), I would keep this value lower(1 Day or so) to prevent WU's from not being completed before their deadlines.
http://www.ndesk2.net/images/17.jpg
Next we move onto the disk and memory usage tab, once again I stress that these are NOT REQUIRED, but rather RECOMMENDED settings to change. Most people here set both "idle" and "in use" CPU usage to 100%, mainly for the fact that even while crunching at 100% CPU usage, it will yield CPU cycles to it your daily computing and gaming, resulting in no major amount performance loss.
http://www.ndesk2.net/images/16.jpg
Thats it! Your done, thats all there is to it! Now get crunching and watch that RAC soar! :thumb:
Chilly December 20, 2008 01:34 PM
Updates
Change Log
December 20 2008 4:32PM EST;
- Uploaded original guide
December 23 2008 2:58PM EST;
- Moved imaged to private server
- Expansion of work buffer recommendation
Chilly December 20, 2008 01:36 PM
Alright guys! Feel free to let me know if there is anything that needs fixing or clarifying, I'm sure that the guide is not perfect(yet!), so I could use all the criticism on making it better! Yes I realize that I went from XP to Windows 2000, my XP's virtual image networking failed horribly, so I decided to just finish using my 2000 virtual machine as the setup process is the exact same on all 3(2000, XP, Vista) OSes.
Supergrover December 20, 2008 02:07 PM
Good Job Chilly!
Thread Stuck!
3.0charlie December 20, 2008 02:14 PM
Originally Posted by Supergrover (Post 129346)
Good Job Chilly!
Thread Stuck!
Agreed, and text edited: it's BOINC, not BIONIC... :bleh:
Chilly December 20, 2008 02:21 PM
Whoops :doh:, this whole time, I thought it was, and was calling it BIONIC, not BOINC when referring to it in speech, in text, etc. :haha:
3.0charlie December 20, 2008 02:24 PM
You linked the pics to imageshack? You should use the Forum's Image Host, so they won't be lost eventually.
D4ng3r December 20, 2008 02:25 PM
Thanks chill, it helped me set up.
Now Im a HWC Folder! :D
Chilly December 20, 2008 02:30 PM
Only issue with the forums image host is that it tends to "shrink" the images. I'll load them up on my personal web server when I get a chance.
Glad to see that its already helping people out! :thumb:
3.0charlie December 20, 2008 03:29 PM
No problem. I don't want the pics lost when it's a stuck thread.
