  #21 (permalink)
Old December 14, 2008, 07:36 PM
LCB001's Avatar
Folding Captain
Originally Posted by Soultribunal View Post
Okay, I'll load another CPU Client on the computer when this work unit is done.
Actually its been a great test to this system and its cooling function.
We'll see what happens when I turn up the heat.
The Cats love to hang out near my computer now :)
ST
A few of the more experienced clockers here use various combinations of the F@H clients for stability testing, it will stress the CPU, GPU, Memory, power supply, everything. If it can't Fold, it's not stable...
Folding For Team 54196
  #22 (permalink)
Old December 15, 2008, 10:01 AM
Soultribunal's Avatar
Well this system here is not capable of an OC, however I am quite impressed with my little MassCool HSF. While folding I do many things, one of which is play WoW on max Settings. Even putting close to 90% on both Cores my system struggles to break the 41-44 Degree Mark. Which is not bad considering the Cooler is Rated for max 2.8 gHz Core 2 Duo.
I usually have way too much stuff running the the Background as well when I am gaming which gets me to the 90% mark.
That being said, I did down-clock my 2600 A little to ensure I don't turn it into a melted hunk at the bottom of my case.
I have no way (that I know of, correct me if I'm wrong) of adjusting the Fan Speed on it so I don't want to risk the card yet.
Thank you CoreTemp/RealTemp for showing me what my system is doing.
If I have problems loading up a second set of F@H software, and the GPU test, I'll post. I didn't get around to it last night.
Best Regards,
ST
www.realhardwarereviews.com
  #23 (permalink)
Old December 15, 2008, 08:22 PM
Update!!!!
Okay F@H Canucks! GPU Folding is now running as well!
So I am 94-97% on Both Cores!
And 96% on the VPU!!!!
Running a Stable 45 Degrees Across the Boards (VPU Included!)
Thanks Everyone for getting me in on the action, My Computer is now devoted to this 24/7!
This will for once and all truely test the build I have.
ST
  #24 (permalink)
Old December 15, 2008, 08:31 PM
LCB001's Avatar
Folding Captain
Update!!!!
ST
Good stuff, you should be running up the charts pretty quick...
  #25 (permalink)
Old December 15, 2008, 08:42 PM
Thanks goes to everyone here so far!!
I'm just here to give what two cents I own.
And to now help Fold!
ST
