Old May 14, 2007, 08:50 PM
Fallen Folder
Originally Posted by Babrbarossa View Post
I'm looking into a potential source for high speed interenet- if it works out, I'll be folding.
You can get a start folding even on dialup but prolly only for lower pointage single core wu's unless you are only constrained by bandwidth, not connection time or consumption cost.
Or even by sneakernet for the bigger smp wu's as long as you have frequent enuf access to a higher speed connection via laptop, or using a thumbdrive and a suitable host pc.
These workarounds do take more work on your part. Let me know if you want to pursue it and we can figure out something that works for you. High speed access is easiest tho since it takes no extra work on your part once setup.
Old May 16, 2007, 07:43 AM
Fallen Folder
We are now ranked #2100 according to Stanford Folding@Home
About 10K more points to go
Old May 16, 2007, 05:05 PM
Supergrover's Avatar
Originally Posted by sswilson View Post
I'm a bit concerned though that we'll fall back out of the top 2000 once the matching is gone......
I'll be putting my other three computers onto this team starting this weekend, hopefully we'll get some new members to fill in the gaps.
Okay, Okay, I'll reinstall on the main and get the rest this WE.
IDK how long I will keep them up but for a month @ least.
1.3 and 2000+ will be 24/7 but not mine.
If anyone wanted to do up a newer FAQ, go hard and I will nuke mine.
R.I.P.
Old May 16, 2007, 07:02 PM
sswilson's Avatar
Heh.... I've now got 3 rigs folding under sswilson, & the kjwilson is my young lads computer (he's now got the 3700 running @ 2860 under air with the DDR running 520.... :) ).
Old May 16, 2007, 07:49 PM
Fallen Folder
I think we will be showing on eoc stats by tommorrow AM
Old May 16, 2007, 07:55 PM
sswilson's Avatar
If you can spare the time, once we make the top 2000 could you possibly post a set of links (I'm assuming they'd be permanent) for team stats?
I'll throw them up into a separate thread as a sticky at the top which will make it easy for folks to check our progress. (Or you could make the thread yourself if you wish and I'll just sticky it).
Old May 16, 2007, 08:04 PM
Fallen Folder
given the small size of the HCF team we need to try to keep everyone active, even if only a single core instance. If you run it from the startup folder (ie not as a service) it it easy to stop it (ctrl-c) whenever you need to and restart from an icon when rig is idle. Just take it out of the startup folder when you are doing stuff/rebooting a lot and all it will consume is a bit of disk space.
I thought you did a good job with it.
I will look it over again. A lot of the basics never really change ... just client selection really.
We could probably set up some how to's even if just by linking to other folding teams sites.
There should also be some new stuff when the V6 client comes out. I expect i will get an early look at it since i am a beta tester.
Old May 17, 2007, 10:32 AM
Scratch's Avatar
Hardware Canucks Forum - Team Summary - EXTREME Overclocking Folding @ Home Stats
we're on the board
  #19 (permalink)
Old May 17, 2007, 12:48 PM
Yeah I know but the thing with these rigs is they are on 24/7 and unsupervized ( as in no Supergrover ) with no AC, and it gets hot like heck here.
*cough* Beta Testers have a NDA *cough*
R.I.P.
  #20 (permalink)
Old May 17, 2007, 02:58 PM
QuadZilla & The Four Horsemen
Mining Bitcoins with: 7x6950, 3x5970, 7x5830, 2x5850
< 3 weeks for HCF folding team to hit the top 500!!! pscout HardwareCanucks F@H Team 24 October 11, 2007 09:32 PM
Countdown - HCF Folding team to the top 800? 3.0charlie HardwareCanucks F@H Team 18 August 8, 2007 06:10 AM
Countdown - HCF Folding team to the top 1000 3.0charlie HardwareCanucks F@H Team 36 August 5, 2007 04:30 AM
AMD Athlon XP 2000+ Palomino & Cooling Tartan2007 CPU's and Motherboards 4 April 23, 2007 08:54 AM
AMD XP 2000+ Athlon Palomino Tartan2007 Overclocking, Tweaking and Benchmarking 7 April 15, 2007 08:13 PM
