Old November 25, 2008, 12:13 AM
Dashock's Avatar
This will be the first thread i have ever subscribed too... as im not familair with rosetta im guessin looking at the pic that 3.0Charlie posted each cpu takes around 4 hours to complete a task how many points does that give you ?
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old November 25, 2008, 01:17 AM
Originally Posted by SugarJ View Post
E8400 @ 3.8 Ghz
3980 fp MIPS per CPU
8301 integer MIPS
Quoted from Charlie
Number of CPUs: 8
2651 floating point MIPS per CPU.
6653 integer MIPS per CPU
Its like having 7 8400s in one.
Old November 25, 2008, 06:03 AM
Jon_di2's Avatar
Not at home right now so here is my work comp: a Pentium D Cpu @ 3.4
1697 floating point MIPS
2692 integer MIPS
ps. damn I though I was going to catch up to you at some point Charlie!
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old November 25, 2008, 06:08 AM
3.0charlie's Avatar
Thanks folks, good data to compare chips.
RAC is still very low, 105.91.
Hydro-Quebec is salivating...
Old November 25, 2008, 06:47 AM
matsta31's Avatar
Rack takes a lot of time :)
For the integeter MIPS, I found that the Ram speed at a lot of influence on it.
my QX9560 at 4.1 had close to 4000 Floating point MIPS and this was giving my a RAC of 3000 ish.
edit :
this is the biggest RAC (!) :
Computer summary
it is a Xeon baseed 8 cores (daul socket server board) :
Measured floating point speed
3231.99 million ops/sec
Measured integer speed
9331.75 million ops/sec
Sold hardware again.....
Currently using WHS hardware....
Old November 25, 2008, 06:01 PM
3.0charlie's Avatar
Latest update:
RAC: 238.49 (from 105.91)
2653 floating point MIPS
6721 integer MIPS
Old November 25, 2008, 06:20 PM
LCB001's Avatar
Folding Captain
Interesting, while the floating point MIPS stays consistent with the proc speed, the integer MIPS seems quite a bit higher on the 45nm chips...
Folding For Team 54196
Old November 25, 2008, 06:22 PM
sswilson's Avatar
That is per core though isn't it?
I'm also guessing that 8 cores is due to hyperthreading?
If I'm reading this right.... My quad at 3.74 mem 1110
3491.96 Floating point MIPs
7950.95 Measured integer speed
  #19 (permalink)
Old November 25, 2008, 06:32 PM
3.0charlie's Avatar
You are correct Sir. 8 Cores due to HT.
  #20 (permalink)
Old November 25, 2008, 06:35 PM
sswilson's Avatar
The #s I gave above were from the "view computers" info.... benchmark from messages were...
3683 Whetstone
8048 dhrystone
