Old November 24, 2008, 04:48 PM
BrainEater's Avatar
Default questions.
Ok.....
I finally cleaned up my 8800GTX and am folding with it.(finally)
I've got some questions I did'nt see answered , so here they are.
I'm using the latest GPU2 client , on forceware 175 drivers.I'm not using the latest drivers , because with my duallies (2 separate video cards) I need drivers that do both an FX5500 and and 8800GTX......The 180's (latest forceware) won't.
I am running with no OC.
I assume the 'lag' when starting/stopping "Fahviewer" is expected ?
What is ns/day under 'performance' ?
TYIA
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Old November 24, 2008, 04:50 PM
3.0charlie's Avatar
Euhhh... which GPU client are you using? 'cause I never saw a Performance tab...
Don't use the viewer, it's bugged.
Make sure you have Physx installed, and oc strictly the shaders for max. ppd.
Old November 24, 2008, 04:59 PM
BrainEater's Avatar
The latest gpu2 client.620r1
The performance thing comes up with fahviewer....If it's buggy , that would explain it.Is there an alternative ?
I'm not OC'ing it.....
Old November 24, 2008, 05:11 PM
3.0charlie's Avatar
Which GPU client, the System Tray or the Console? I think you're using the System tray.
I don't even now what does the viewer... if you which to see your ppd, use FahMon.
Old November 24, 2008, 05:33 PM
LCB001's Avatar
Folding Captain
Glad to hear your getting your GPU going, you'll like the points. Performance: ns/day is one of the stats shown on the viewer available on the Systray client. From what I've read on the F@H forums the console client is supposed to be more stable and use slightly less resources, I use both and don't see much of a difference...
Home | FahMon for monitering your client, new posts in the fahmon thread suggest the new update might be a little buggy...
I use FahSpy - FahSpy - powerful monitoring tool for Folding@Home distributed computing just personel preference...
Folding For Team 54196
Old November 24, 2008, 05:59 PM
sswilson's Avatar
When you're trying to set up FAHMon point it towards the same folder as is listed in your FAH start/programs (expert only) data files.
Old November 24, 2008, 11:09 PM
Dashock's Avatar
Btw to add to only overclocking the shaders, Run with vista as it uses less cpu resources and you can underclock your cpu i have mine at 1.6 and i see no performance hit. Cheers and welcome back. We need more for the fight!
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old November 25, 2008, 06:33 AM
BrainEater's Avatar
yea it's the systray clent.I will probably switch to the console version , I just wanted to see the systray one.
It's humming along.
Old November 25, 2008, 06:40 AM
3.0charlie's Avatar
The Systray Client works fine, but I like being able to see the Client log in real time when using the Console version. How's the temps on the 8800GTX?
Old November 25, 2008, 06:53 AM
BrainEater's Avatar
68 C is the hottest i've seen it , it's usually 65 ish.
That's with no OC and stock everything.
