Originally Posted by chriskwarren I understand the problems doing this benchmark Sky so no problems there. I was mostly wondering if somebody out there was doing this or if somebody in our community could do something like this and post in the forums via sticky, etc. I don't have the time but mostly resources ($$$) to do so, but I believe that there is a great opportunity for a reliable benchmarking site to gain readership. Perhaps somebody smarter than I can create a benchmarking utility that simulates fah crunching that would make this easier. |
The Tech Report has been doing it for a couple years now(maybe a bit less)..but their results are extremely low. They use what i would say is a "script".. a CD that one of their forum members made.. to bench F@H. Actually, come to think of it.. it was for CPU's ... not GPUs.
Anyways..it would be interesting to do/see. I think as others have mentioned, that if you DL a WU for ATI and one for nVidia..save them..then when you run it.. make sure to unplug from the net. Just delete the "work" folder after each run..then you're all set for the next. I don't think that Stanford would be too happy about people DLing WUs as benchmarks though, but you wouldn't have to do it very often.
