Old October 30, 2008, 08:22 PM
biff's Avatar
Default How hardware intensive is boinc?
I am playing with a linux box and don't have access to a lot of the usual OCing software like cpu-z for instance. I'm wondering how intensive boinc is, can it be considered equivalent to orthos to test stability and thermal control since both use 100% CPU?
I'm not really trying to use boinc as an alternative but rather I don't want to take boinc off line while I run a stability test for days to find a stable OC. I realize that if it craps out I lose the work that has been done on that task but if it does stay stable long enough then atleast something worthwhile came out of it instead of just a bunch of wasted hydro running orthos.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old October 31, 2008, 04:44 AM
3.0charlie's Avatar
Consider this: 2 weeks ago I oc'ed my Q9450 to 3.9GHz stable using the following final tests: OCCT 2 hours, Dual 32M SuperPi and P95 20 hours. Enough, right? But within 4 hours of using BOINC, I had errors. I had to back down to 3.8 for BOINC stability.
BOINC and Fah (CPU) are possibly the toughest 2 apps out there for rig stability. They don't generate as much heat load as the others, but they do push the chips to their limit.
Hydro-Quebec is salivating...
Old October 31, 2008, 04:45 PM
Yea, and thats what I did to burn in my quad in my sig when I left for the gold mine camps. I set World Community grid to run 4 instances of boinc at 100 % on a mildly OC system. I ran it for 30 days straight LoL and no hiccups. But, my mom says the whole upstairs was toasty warm hehehe.
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
Old November 1, 2008, 12:22 PM
biff's Avatar
Thanks... As soon as I figure out how to make linux stable I can get to some boincing/OCing.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
