Old October 7, 2008, 07:11 AM
Dr_BenD_over's Avatar
Fallen Folder
Default My 9800GT seems subpar
Performance wise, I haven't been able to bust 4K a day on it. And I've seen people that get over 5K on 8800GT/9800GT's
e6300 @ stock, one core running the regular old console, the other feeding the GPU
XP Pro
178.13 drivers
Gainward 9800GT 512MB @ default clocks
FAH client 6.20r1 built Aug 12, 2008
All's well that's Haswell
Old October 7, 2008, 07:18 AM
sswilson's Avatar
Couple of things.... believe it or not..... the GPU client actually runs better under Vista!!!!! :)
The stock clocked E6300 might also be costing you a few hundred PPD (try running it without the console and I think you'll find a boost to GFX PPD).
Old October 7, 2008, 07:30 AM
Dashock's Avatar
Hey bend just giving yea some suggestions try only overclocking the Shaders on the card i have my Cpu underclocked to 1.4ghz and im still getting the same ppd 5249pdd. And like SSwilson said use Vista lol but dam its such a memory hog. Btw i set my Shaders to 1850 at 1860 i get errors so 1850 has been safe and true for me, im sure yours can achieve the same as well.
BTW just an update guys if some remember i was testing cpu freq with ppd on the gpu console there seems to be no correlation. Even underclocked to 1.4ghz but yet same shaders at 1850 results in same ppd.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old October 7, 2008, 07:32 AM
3.0charlie's Avatar
Vista is better than XP for ppd.
Use 177.92 drivers with Physx support.
Stock card - only overclock the shaders for max ppd output.
The stock CPU may have an impact, but nothing compared to the other points.
Hydro-Quebec is salivating...
Old October 7, 2008, 07:53 AM
1Tanker's Avatar
I've done the same thing Dashock. When my E6600/9800GTX+ is Folding downstairs, i downclock it to 1.8GHz or lower.. to help lower the energy consumption/heat. It doesn't lower it a lot, but it doesn't hurt PPD.. so why not?
Old October 7, 2008, 08:10 AM
Dashock's Avatar
Just trying to save us all money!
Asus P5Q-E
Corsair Cx600M
Old October 7, 2008, 09:15 AM
Fallen Folder
Hmm. With one console client running usage of the GPU core was maxing out at about 20% of CPU1 (remaining 30%ish was idle). By killing the second CPU core running on CPU0 the GPU core CPU usage goes up to 50%. I don't appear to have this problem with the Ati client, but I'd better double check when I get home.
Thanks everybody.
