Old October 3, 2008, 12:47 AM
Apollo4g's Avatar
Default Folding setup help with a 4870X2
Hey all, well i setup my watercooling for my 4870X2.
I installed the folding gpu client.
When i turn it on it only uses 1 core.
So i looked it up and found the instructions on the folding site.
What about multi-gpu support?
Yes, you can add the "-gpu N" flag (N starts at 0) to your extra parameters in the advanced page of the systray clients, or the advances settings of the console clients. Again N starts with 0 not 1, so your primary display is 0, the next is 1, etc. Each client if you are running more then one needs a different -gpu and a different machineD, and a different working directory, so follow the instructions for multiple clients.
My question is, do i need to install 2 folding gpu clients? So i can then enter that "-gpu 0" and "-gpu 1" in each?
Steps please.....noob here :)
Also do i have to have a log in and password to run the client on both cores?
Help please? Thanks
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 3, 2008, 04:16 AM
Dr_BenD_over's Avatar
Fallen Folder
There is a guide here for multi GPU's
(disabling Cat. AI disables CF)
All's well that's Haswell
Old October 9, 2008, 07:07 PM
Fallen Folder
Well, I can't get that procedure to work, and it's pretty much what I did when I had 2 3870's. Guess it's still not X2 friendly.
