Old October 2, 2008, 07:04 AM
BrainEater's Avatar
Default SMP client errored
Ok.....yesterday for some reason , my fah client errored out , it's now saying 'missing work files' and it won't restart......so I guess i need to clean out the bad files , question is , which ones......
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Old October 2, 2008, 07:08 AM
3.0charlie's Avatar
They are found in the Work folder - simply delete the whole folder, and re-start the Client. The folder will be recreated.
Downside is that all WU work is lost.
Old October 2, 2008, 08:31 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I find once that error shows up it doesnt go away if you delete the work folder or not. I usually delete the folder and reinstall.
Old October 2, 2008, 08:39 AM
You may even want to consider a a RegClean as well before the re-install and DL the client again. Start completely afresh.
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
Old October 2, 2008, 03:23 PM
BrainEater's Avatar
Nah all that's not necessary.....I was just thinking if I could only delete the problem WU files , but I forgot about queue.dat....
It is , in fact identical to the normal client.....John's correct , delete the work folder , but you also need to delete queue.dat from the main folder too....
I was not able to save the WU tally but whatever....It's humming alone nicely again.
Was a funny error........I was browsing the web , looking thru my HDD's and opened VLC up.....*bink* Fah errored immediately......I'll have to see if it's repeatable.
Old October 2, 2008, 03:27 PM
3.0charlie's Avatar
Problem with the queue.dat file is if you have un-sent WUs, you loose them too. Sometimes you may have no choice but to do it...
Eldonko's Avatar
It is just buggy still, happens when you open certain programs sometimes.
Old October 9, 2008, 01:29 PM
Xilikon's Avatar
Actually, you can salvage it by doing a -send all command to send any unsent units before deleting the work folder and queue.dat. When you are sure there is nothing to send, delete it. Deleting the work folder without touching queue.dat is pointless because queue.dat is just a pointer to the files in the work folder which doesn't exist if you deleted it.
Xilikon - Team 33
Proud to be [H]ard !
Old October 9, 2008, 05:50 PM
BrainEater's Avatar
Cool....
I've actually ended up reinstalling it....I looked at my logs , and it was installed while OC'd.....I got a bunch of EUE's....after the original error.
running like a champ again.
