-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   Ok, lets talk about boxen. (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/10278-ok-lets-talk-about-boxen.html)
BrainEater September 22, 2008 08:04 PM
All competitive nature aside , let's get HWC into the top 100.
:biggrin:
I have use for a fair 'heatsource' to heat my hallway cement floor.I intend to run 'hydronic' heating lines into the hall floor and tile it , and it seems to me a watercooled high performance boxen might supply heat.
hehe
Any thoughts ?
:thumb:
3.0charlie September 23, 2008 04:42 AM
:biggrin:
hehe
Any thoughts ?
:thumb:
You want to do what? :shok: Heat your tile floor using a lines coming from water-cooled rigs?
It can be done, the heat transfer to the cement should be high, but in order to "heat" the floor, forget CPU folding - you'll need a s*** load of nVidia cards... and the question is: how many? And which one? 8800GT would be a good choice - cheap, sufficient heatload.
That would be one heck of a Folding Farm.
LCB001 September 23, 2008 05:23 PM
Make for some nice points. Trust BrainEater to come up with that kinda idea, sounds interesting. Can you imagine the tubing he'd need for that loop...
Cptn Vortex September 23, 2008 05:28 PM
You guys are funny
3.0charlie September 23, 2008 05:42 PM
Reminds me of a water-cool system I once saw using copper pipes 4 feet in ground - which acted as a rad. From what I can remember, it worked great. He could do the same but have the copper pipes imbedded between the cement floor and the tiles.
BrainEater September 23, 2008 06:05 PM
I should explain a bit better.
A picture is worth a thousand words , so ;
http://braineater.kicks-ass.tv/miscshite/base1.jpg
Ok , so , the bottom part (where you see the wood desk) is my LAN room , It's where all my computers are.When I built it , I insulated it for serious sound dampening , prolly r-45 level insulation , as well as frequency layers , so needless to say heat tends to stay.Currently , I have the room actually vented for heat at 300 CFM.
5 steps up , is the main entrance hallway.You can see two doors there , one is my front door , one is the door to the garage.That floor is currently crap lino.it's 3' by 16' concrete prolly 6" thick.
Here's the deal.My garage and front door face north.They never get sun.The garage , and that floor are ALWAYS cold.....
So the thought crossed my mind , if I could move heat from a-to-b , my LAN room would be cooler , and the floor would be warmer. :biggrin:
My actual idea of 'heating the floor with water loops' is waaay down the road , cause I'm the guy thats gotta do it all....hehehe , but the heatsink is there without question.
If I'm going to build a minor folding farm ( which I am) I might as well use the heat.I think I might try pumping the hot air from my rack and main rig out to the floor , but watercooling really would work better.
Just something I'm tossing around in my head.
:thumb:
3.0charlie September 23, 2008 06:12 PM
Definitely feasible, with very little parts. A good pump, a res, GPU blocks and of course copper tubing. But something else caught my eye:
That's new?
SugarJ September 23, 2008 06:14 PM
:thumb:
Yup. Just run a long loop to the area, mount your rad and fans there. Bingo. Heat pump.
If you wanted to get real fancy, use one of the radiant heat tile mats, attach to your concrete, run your loop through that. Or just attach your loop direct to the concrete, use it as a large heatsink.
Enough dumb ideas? Good luck with it. But finish the Think Tank first, will ya?
BrainEater September 23, 2008 06:19 PM
Hehe
'Farm' is probably a bad word , but , I usually have 3-4 rigs at least running 24/7/365 ..... I might as well make my 1 server a folding boxen.( I have to upgrade it tho).... I could potentially add 6 clients with a good upgrade.
:thumb:
yycraven September 23, 2008 06:21 PM
Well you will have your own small Geothermal heating and cooling system
Nah! farm is a good word. haha basically this here but in a smaller version.
http://www.hardwarecanucks.com/forum...996700f172.jpg
