Old September 23, 2008, 06:25 PM
3.0charlie's Avatar
Farm is definitely the correct word.
Hydro-Quebec is salivating...
Old September 23, 2008, 06:37 PM
BrainEater's Avatar
That picture is exactly correct yycraven.
For 7 months of the year my garage is 5-7 c....I'd love to smash out the floor there too and heat it with a loop.
In the winter , I need to heat my garage with a propane heater to be able to work in there.
Heat from a-to b.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old September 23, 2008, 06:52 PM
yycraven's Avatar
Heat from a-to b.
No need to smash your cement floor, what size of line do you think you will use.
if you use 6 to 8 systems you should heat that floor in front of the doors pretty good.
Now for the garage well, hmm you will need more then 8 systems.
Old September 23, 2008, 08:03 PM
Dashock's Avatar
A bunch of 280's or GX2 might do the trick. The GX2 are getting cheaper and cheaper day by day so that might be a good heat source. If this does work this would be one awesome build BrainEater
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
