Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Hardware Canucks Store
Old October 25, 2011, 02:07 PM
Your_friendly_gamer's Avatar
Default HWC thermal compound review
I just received my application last week and finally applied some on the weekend. It was on sale and free shipping so about 30 I paid I think. ANyways it's not about the money.
THe compound is sticky, not your normal compound where you can take a credit card and spread it. It will stick to it. I used the 3 lines and then put my heatsink on top and twisted it a few times. 3 thin lines of course.
Anyways it's amazing, i was using Arctic silver 5 before.
My temps have dropped at least 5 degrees, the idle temps are the same. It's the load temps. At 4.5ghz for Linx I would hit 58 degrees max, now 52-53 degrees, when I am gaming I dont hit 50. The only thing that was changed was the thermal paste.
HWC store, thank you for such a great compound.
In case you are wondering my components:
i72600k at 4.5ghz
Proliamatech megha with 2 coolermaster blade master 120mm fans in push pull config.
Old October 25, 2011, 04:01 PM
Supergrover's Avatar
Shits nasty coming off though and really stiff, I found the pea method way better for this stuff.
That said it worked well and makes a wicked lapping compound......
R.I.P.
Old October 25, 2011, 05:08 PM
sswilson's Avatar
QFT
I got great results with it, but I've now also got about 4 procs which no longer can be identified without plugging them in. ;)
Thermal Compound Review no_pulse CPU's and Motherboards 5 July 23, 2008 01:50 PM
Arctic Cooling MX-2 Thermal Compound Review @ OCIA.net SKYMTL Reviews & Articles from the Web 1 September 24, 2007 07:22 AM
