-   Hardware Canucks Store (http://www.hardwarecanucks.com/forum/hardware-canucks-store/)
-   -   HWC Hats have arrived!!! (http://www.hardwarecanucks.com/forum/hardware-canucks-store/23528-hwc-hats-have-arrived.html)
Gav September 24, 2009 04:40 PM
Here they are. :canadianwave:
Pro Fit Hat w/ Plain Front w/ HWC Logo on back - $19.99
Pro Fit Hat w/ Maple Leaf on Front - $24.99
Pro Fit Hat w/ Maple Leaf on Front & HWC Logo on Back - $29.99
Kilauea September 24, 2009 04:48 PM
Now, I just need some sort of information about what size S/M is and what size L/XL is.
chrisk September 24, 2009 05:01 PM
I have a large head so the large was probably good for me. If not, I'll throw it in hot water and dryer for a few cycles.
Got the one with the logo on the front and back. Thought hard about the one with the back logo only though.
Gav September 24, 2009 05:13 PM
I was told that the majority of people will want to go for L/XL as it's considered the norm. S/M is more of a kids size.
Kilauea September 24, 2009 05:23 PM
Ok, I normally have a small head... but I guess I will give it a try with L..
SKYMTL September 24, 2009 05:41 PM
Give us a circumference please.
Kilauea September 24, 2009 05:46 PM
Not sure if you were talking to me or to Gav, but my head's circumference is 55cm.
Gav September 24, 2009 09:49 PM
I think he was talking to me.:biggrin:
I'll take a look tomorrow and give the "unstretched" circumference. Keep in mind that they are A-Flex caps so they do stretch.:thumb:
martin_metal_88 September 25, 2009 07:29 AM
Maybe you should add circumference in the product page?
Ask for more.
Gav September 25, 2009 12:02 PM
Ok, I just measured the circumference of both hats and they are exactly the same (58cm).
It seems to be that the L/XL hat is just physically bigger, the panels seems to be slightly taller and wider. They both have stretchable headbands so they're quite forgiving with regards to different head sizes.:biggrin:
