Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Hardware Canucks Store
Old May 2, 2009, 06:16 AM
Nademon's Avatar
I wish I could give you an exact number and I'll look into it. Real world example...I've had a tube sitting around for about a year since I last used it and I just tried to use it last week and it was still perfectly good. As long as you put the cap back on tight and store it in a cool, dry place and out of sunlight, you shouldn't have any issues. It's pretty stable stuff because there's no solvent in it, so there's not much there to evaporate.
If you're referring to a new unused tube, it'll be good for quite some time also as long as you store it well. If ever you have issues with a brand new tube, just shoot me a PM.
REFS:
My Heat, Ebay, RedFlagDeals
Rig 1: CM HAF - Rampage Extreme - QX9650 - OCZ Gladiator Max - 4GB Mushkin DDR3 1600 - GTX280 - 2xBarracuda 500GB - 1xBarracuda 250GB - Pioneer DVD - Corsair 1000HX
Rig 2: Thermaltake Armor - P5K-E - E3110 - TRUE w/ 2 120's - 4GB Ballistix DDR2 1066 - 9800GX2 - 2xBarracuda 250GB - Pioneer DVD - Corsair 620HX
Rig3: Antec 900 - P5K-E/Wifi - E5200 - OCZ Vendetta 2 - 4GB OCZ DDR2 800 - 2x 8800GTS's - 1xWD Caviar 80GB - Pioneer DVD - OCZ 650W PSU
Cooling innovation ic7 tim tests mo' power Overclocking, Tweaking and Benchmarking 5 March 16, 2009 03:49 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 06:17 PM
change of thermal compound v0maru CPU's and Motherboards 0 March 18, 2008 08:13 AM
Arctic Cooling MX-2 Thermal Compound Review @ OCIA.net SKYMTL Reviews & Articles from the Web 1 September 24, 2007 07:22 AM
