| by MAC | August 31, 2008 | ||
| Specifications Specifications![]() The EP45-DQ6 is based on the recently released mid-range Intel P45/ICH10R chipset combination. The P45 is Intel's second-generation mainstream chipset to be manufactured on the 65nm process, which is a sizeable shrink from the 90nm X38 and X48 chipsets. As a result, the northbridge has a very low default voltage of 1.10V, which means it also runs cooler than its predecessors. Officially, the P45 does not support the newest 1600Mhz FSB specification, as found on the high-end Core 2 Extreme QX9770 quad-core processor. However, all motherboard manufacturers (aside from ECS) are marketing their models as FSB1600 capable. Memory-wise, the chipset has been validated for operation up to DDR3-1333 and DDR2-800, but several manufacturers have certified their own models for operation up to DDR3-2000 and DDR2-1333+. On the PCI Express front, the P45 is limited to 16 PCI-E lanes, just like its predecessor the P35. However, the P45 chipset supports the PCI Express 2.0 specification, which doubles the standard bus bandwidth from 2.5 Gbit/s to 5 Gbit/s. This in itself is not particularly noteworthy, since the real-life performance differences between PCI-E 1.0 and PCI-E 2.0 are quite miniscule. However, the P45’s standout feature is that its PCI-E 2.0 slots can work in either 1x16 or 2x8 configuration, which is unprecedented for a mainstream chipset. In effect, a proper CrossFire configuration, no more crippled x16/x4 CrossFire nonsense. It’s not a full-blown x16/x16 setup, but no one could realistically expect Intel to allow a mainstream chipset to share the technological limelight with the higher-end X48. While the P45 chipset is the first to benefit from the new ICH10R southbridge, there is not much to report... The ICH10R is effectively identical to the previous ICH9R southbridge, both support six SATA II ports, AHCI, and Matrix RAID technology. Now let’s see what kind of motherboard Gigabyte has built around this new chipset. ![]() | ||
