CoolIT Boreas MTEC Chassis Review
by AkG     |     September 8, 2008
Testing Methodology
To ensure that the results from one review to another are not only reproducible but actually pertinent to this review, the Testing Methodology will be the same throughout all reviews used. If something does change we will be sure to make a special note of it and explain why this change was done and more importantly why it had to be changed or altered.
Except where noted all comparison testing was done on an open bench with an ambient temperature of 20c. Recorded temps were as reported via CoreTemp's "Temp Log". Average load temps were taken after 15 minutes of running Prime95 v25.4 “small fft” and are taken directly from CoreTemp’s temperature text file. Excel was used to average the results of all cores. Idle temps were taken 15 minutes after Load testing ceased. Motherboard temperatures were recorded using SpeedFan. For any and all water cooling units no fan speed control was used; rather, they ran at full speed for all testing stages. Since this hybrid cooler has built in fan speed control we let it decide the speed of the fan.
Arctic Cooling MX-2 thermal paste was used for all coolers during these tests unless otherwise noted. Application of all thermal paste was according to the manufacturer’s instructions and while not necessary it was allowed to cure for 48 hours under moderate to high loads (with periods of low loads) prior to testing.
All tests were run a minimum of 4 times and only best results are represented.
Please note: Because the Asetek LCLC did not come with a fan, the fan which came with Swiftech H20-120 was used to obtain the results listed in this review.
Please note: Because the Swifteh H20-120 is not a sealed maintenance free unit, pure desalinized water with Swiftech Hydrx was used.
Notes about Overclocking:
For q6600’s I consider 1.45 volts to be the most that I would seriously consider for a moderate-to-long term overclock.
Yes you can go much higher but the longevity of the CPU is then called into question. Just as importantly the CPU should average out at LESS than 65c as this is also what I consider the safest, maximum long term overclocking temp. For the purposes of these tests I was willing to overlook temperatures as long as they averaged below 70c and did not peak over 75c. If 75c was displayed for more than 10seconds in CoreTemp all testing was stopped and that test run was considered a fail.
With these two general guidelines I overclocked both systems until either one (or both) of these "rules" was needed to be broken to continue.
Overclocking was accomplished by increasing FSB speed and then Vcore (only if necessary).
As they have no bearing on these tests the RAM’s voltage and timings are not recorded, the RAM was set to run at or as close to as possible PC-6400 speeds by running various cpu : memory dividers. Please do not consider this a full “how to” review on overclocking or “safe guidelines” for overclocking nor even an indicator on how well a given CPU will overclock. IF you are interested in OC’ing your system, and use these guidelines we at HWC take no responsibility for the results. Bad Things can happen if you are not careful.
Complete Test System:
Processor:
Intel:
Q6600
AMD:
Phenom 9750
Motherboard:
Intel:
Gigabyte p35 DS4
AMD:
DFI LANPARTY UT 790FX-M2R
Memory: 4GB G.Skill PC2-6400
Graphics card: ASUS 8800GT TOP
Hard Drive: 1x Western Digital Se16 500GB
Power Supply: Seasonic S12 600W
Latest Reviews in Cooling
October 12, 2011
September 29, 2011
July 14, 2011
